Jesus_man wrote:That is intriguing. $1300 for a DIY kit that seems to come with the truss and the links. So I'd have to come up with frame brackets, coils, and shocks.
Another $530 gets you the whole kit minus the sway bar.
Or the dual sport kit sans sway is @$2500.
Food for thought! Thanks!
That's awesome. 3rd place in a class that probably included somedbasile wrote:I thought about linking mine too. But I am cheap. 3rd place on the rti at Super Celebration West in the extended wheel base class with leaf springs.
I got the leafs from a 99 escalade. The big deal is 5 1/2 front springs with a little less that 4 inches of lift. I moved the rear back qbout 4 inches and am just shy of hitting the crossmember or the fuel tank.
Prior to my changes I too had terrible rear wheel hop. Gone now. I also installed bigger spring perches, this may have helped.
Jesus_man wrote:Understood. It's a bit of trial and error, but once you weld it down, it's not fun to pull it back off.
For clearance reasons, I think I still want to stay with shackle over as, so then I am really back to the drawing board if I would decide to run a different type of spring. Just a quick search yielded that most lift kits for this genre of Chev use blocks for the rear. BDS has a $583 adder if you want full spring packs, but this was for a 1500 pickup, which is likely NOT the same spring rate as our broncos. So that becomes a bit of a mess for me.
Gunnibronco wrote:For the price I'd probably start seriously considering a 4 link.
Gunnibronco wrote:That's awesome. 3rd place in a class that probably included somedbasile wrote:I thought about linking mine too. But I am cheap. 3rd place on the rti at Super Celebration West in the extended wheel base class with leaf springs.
Prior to my changes I too had terrible rear wheel hop. Gone now. I also installed bigger spring perches, this may have helped.linked/coilover rigs.
I'm not sure but our trucks are the only ones I know of running the 54" GM rear springs. Seems like we stumbled on a pretty nice combo.
How did you decide to go this route? It was kind of a whim for me. I saw a chart with a bunch of spring specs and these matched weight ratings with EBs and the dimensions put the axle where I wanted it.
You could not get enough lift from the flat spring without installing the hangers below the frame with a tension type set up. It will take an arched spring.Jesus_man wrote:That's a great video. I wish he would have done with with our stock Tension Style Shackles.
