It is currently Wed May 22, 2024 11:54 pm
[ 10 posts ] |
gclauson
Joined: Sat Mar 26, 2011 9:08 pm Posts: 35 Location: Mead, CO
Misc parts wanted list
I am building a 1966 beater into a trail rig. I'm looking for these parts- they don't need to be perfect, some dents or rust is probably okay.
Upper coil spring retainer clips Lower coil spring cups Leaf spring shackles Lower center firewall sheet metal (angles between vertical firewall and top of transmission tunnel)
1966-67 doors and/or door parts 1966-68 grille (small turn signals), headlight buckets, trim rings, etc Tailgate latch handle assy License plate bracket assy 1966 steering column dash surround (metal and the rubber part) 1966 ashtray Steering column support bracket that attaches to firewall with 3 bolts and the column clamps to it
Perhaps someone has these takeoffs in a junk pile and will unload them cheap or free? Just need to make a rolling chassis until I get "real" axles - Dana 30 hubs, spindles, drums, axle shafts, drive flanges or lockout hubs - Ford 9" 28 spline standard axles (preferably with big bearing retainers)
Call or text at 303-578-8432 Gary
Tue May 31, 2022 2:45 pm |
Re: Misc parts wanted list
I probably have the 9” axles, and possibly some other small parts, I’ll look in storage.
Tue May 31, 2022 5:34 pm |
I have some lower spring cups.
Tue May 31, 2022 10:44 pm |
I've got a few axles. Not sure about the retainer size. They're rusty, but you can have them.
Wed Jun 01, 2022 7:34 pm |
Friday
I probably have these. I can check in my parts pile. Tailgate latch handle assy License plate bracket assy
Wed Jun 01, 2022 8:54 pm |
gclauson
Thanks to everyone- I believe I have PM replied.
I could also use a set of 4 steel wheels with tires that hold air. Don't need to be OEM Ford, but more narrow/stockish width (5-6") and smaller tire size (<31 x 9" or so).
Gary
_________________ 1966 Bronco. 351W with Explorer fuel injection, Cage 3.5" lift w/long arms, 2" body lift, NV4500, 4.56 ARB front D44/Detroit Locker 9" rear, 35" MTRs, hydroboost brakes and 4 wheel disks.
Thu Jun 02, 2022 6:38 am |
gclauson
Updating the list for what I am still looking for:
Perhaps someone has these takeoffs in a junk pile and will unload them cheap or free? - Dana 30 hubs, spindles, drums, axle shafts, drive flanges or lockout hubs
Wed Feb 01, 2023 6:03 pm |
BOBS 2 68S
I have the most of the Dana 30 parts from a disk brake conversion. I don't have any 30 axles.
Thu Feb 02, 2023 5:37 am |
Thu Feb 02, 2023 8:31 am |
I have a license plate bracket assembly, I even know where it’s at in storage.
Thu Feb 02, 2023 6:07 pm |
[ 10 posts ] |
