Ring gear pattern
Ring gear pattern
Postby BOBS 2 68S » Thu Sep 29, 2022 3:18 pm
Tell me if this pattern looks good. This is my first time rebuilding a rear gear. New USA Gear set (4:11), back lash .006-.016 set at .011.
I ask because I just put it together and set back lash, then checked gear pattern and got what I see as a good pattern.
Pinion is set at 14 inch pounds.
BOBS 2 68S
Re: Ring gear pattern
Postby Digger » Fri Sep 30, 2022 9:48 am
BOBS 2 68S wrote:Tell me if this pattern looks good. This is my first time rebuilding a rear gear. New USA Gear set (4:11), back lash .006-.016 set at .011.
It's a little hard to tell. The pattern looks centered on the tooth side-to-side, but top to bottom is hard to tell.
Can you add more grease and then, a trick I use is to grab the carrier with one hand to create drag, then with the other hand, rotate the pinion yoke in the drive direction. This will apply more pressure to the tooth face and improve the fidelity of the pattern.
Postby Digger » Fri Sep 30, 2022 9:52 am
This was the pattern on mine when it was built. 17 years and 140,000 miles, no problems so far.
Re: Ring gear pattern x2
Postby BOBS 2 68S » Fri Sep 30, 2022 10:30 pm
So I adjusted the pinion out some and got these patterns. They look better in person.
BOBS 2 68S
Return to Chit Chat
