Good choice in jounce bumpers.
Digger wrote:Looking good Chad, glad to see this coming along!
Gunnibronco wrote:Digger wrote:Looking good Chad, glad to see this coming along!
Thank you. Slow but steady progress.
These are the only bumps that I could easily fit. Super lucky to find them unused and super cheap. I'll probably have to make some extensions for the Jounce Stops after adjusting the rear springs.
Digger wrote:Gunnibronco wrote:Digger wrote:Looking good Chad, glad to see this coming along!
I used this kit to extend mine about an inch. You cut and weld the middle tube to set the extension length.
https://www.spcalignment.com/index.php?option=com_spc&task=part_description&pid=25603&Submit_form=Submit
Gunnibronco wrote:I had seen those when I picked up the bump stops and was reading on them. Do you know if they are still available? Summit and the other dealers list it as unavailable. If not, I can always lift the striker pad. I also think I have a few of the 1/2" aluminum spacers that screw together, and I bet they can be modified to work. I think I'll need 2" spacers.
Jesus_man wrote:Nice to have a roller!! Hope you can get the stance more level. Seems like you have good options!
Jesus_man wrote:If you haven't moved it after you put the tires on, it could be that just rolling it 10ft in each direction, might help settle things too. Maybe you've already done that?? But if you did one corner at a time, it's possible the suspension has a bit of a bind on it.
Jesus_man wrote:It's looking amazing!! So happy for you!! Seems wheeling season is already here in your neck of the woods!! Hope to see it hit the trails soon for a solid shake-down!
Kinder wrote:Looking extra beefy, I’ve never heard of a balljoint delete and looked them up, nice bit of kit.
Jesus_man wrote:Killer paint booth!!
Really, I am excited to see you finally get this thing on the trail!!
