It is currently Wed May 22, 2024 8:12 pm
[ 9 posts ] |
Anyone have two Ford nine inch axle shafts
Zenzone
Hi, so I broke both rear axle shafts on my bronco wheeling the other day. Does anyone have any extra 28 spine nine inch axle shafts they are willing to part with or sell? I’m going to build a better axle in the future, I just haven’t done it yet and want to get the bronco drivable again.
Sun Jul 23, 2023 10:05 pm |
Re: Anyone have two Ford nine inch axle shafts
What year 9" do you have? The axles varied depending on if it was a small bearing, small brakes vs big bearing, big brakes, etc.
It all has to do with the brake offset.
I have a set for the 74/75 "medium" duty.
Mon Jul 24, 2023 6:58 am |
Zenzone
I have a 1976 stock Ford 9 inch. I believe that’s the big bearing big brakes year. Thanks for your reply. Let me know if you think what you have would work. I appreciate the reply.
Tue Jul 25, 2023 5:48 am |
I think there were two versions offered that year but big bearing, big brakes are more common in the 76/77's from what I remember.
Measure your brake drum. If it is 11" it's the big brakes.
Mine won't fit as it will have the wrong offset for the brakes.
Tue Jul 25, 2023 5:54 am |
Both shafts?? That takes some effort! Hope you source what you need until you can get some beef under there!
Tue Jul 25, 2023 11:00 am |
Zenzone
Yeah, both axles. I was going up red elephant hill, a trail I have done numerous times In the past and it’s more dug out now and I just happened to hear a pop and one axle broke and I was on my own so I tried to make it the rest of the way out on my own and the other one let go close to the top. So a few guys who were behind me pulled me off the trail where two wheel drive would not cut it and I towed it home. I only have had 35 inch tires and I drive with a light foot but I guess that’s enough to make 28 spline stock axles let go. I’ll keep looking for replacements. Thanks.
Tue Jul 25, 2023 5:37 pm |
Justanother66
Joined: Thu Apr 12, 2018 7:00 pm Posts: 31 Location: Castle Rock, CO
I have a set of ‘76 big bearing big brake axles you can have if you’d like. They have brand new bearings and the Currie heavy duty retainers.
Sat Jul 29, 2023 3:35 pm |
Zenzone
Wed Aug 02, 2023 8:56 pm |
Justanother66
No problem at all! I live in Castle Rock(ish), but will message you my address so we can work out the details.
Fri Aug 04, 2023 12:09 pm |
[ 9 posts ] |
Users browsing this forum: Google [Bot] and 0 guests |
