D20 J shift, D30 front Axle, fuel inj parts, misc
Please post prices in your ad and delete or post up when your items are sold.
Postby gclauson » Wed Nov 22, 2023 12:51 pm
Updated 2/20/25. Price drop on some items. Extra parts that I’m tired of tripping over. If any interest, I'll email or post photos.
Dana 30 from Oct 1966 build. Very nice housing w/o rust pitting. Sand blasted and painted black. Front cover with unique 1966 brass 90 degree filler plug. 4:11 gears not installed. Brand new king pin bearings installed. Front drum brakes from a 1968 (self-adjusting). Missing drive shafts and lockouts. $200
Chopped up Fox Mustang 5.0 harness. Ran this in my Bronco. Modified for EDIS. Could be used, or scavenged for parts. Plus another parts harness. $50
1994-95 mustang flywheel and bellhousing plate. IIRC, 157 teeth, 50 oz imbalance, not for Broncos $50
SBF flywheel 28 oz imbalance 164 teeth. $50
Mustang GT 5.0 upper and lower intake MAF and throttle body. $125
NOS Standard Brand TFI module $35
Heavy duty front shock towers, from Tom's Bronco IIRC. $50
1968-77 heater cables: 1) “TEMP CONTROL”, 2) “PULL FOR DEFROST” $15 each
1968-77 misc dash knobs with set screws $10 for all
Send a PM if you're interested in anything!
Gary
1966 Bronco. 351W with Explorer fuel injection, Cage 3.5" lift w/long arms, 2" body lift, NV4500, 4.56 ARB front D44/Detroit Locker 9" rear, 35" MTRs, hydroboost brakes and 4 wheel disks.
gclauson
Re: D20 J shift, D30 front, Bilsteins.
Postby Gunnibronco » Mon Nov 27, 2023 1:45 pm
If you can ship I'd be interested.
TFI relocation kit- is this the kit with the new TFI module or without?
Can the Bilsteins be installed on a stock front end? Or do the shock towers need replaced with a tower that uses bolts instead of the OEM stud? It's been too long since I worked with a stock front shock tower.
Thanks
Postby D&D72 » Thu Nov 30, 2023 5:48 am
I'd be interested in the bilsteins if gunni doesnt get them.
D&D72
Postby gclauson » Fri Dec 01, 2023 8:14 pm
Sorry, I haven't been on here for a couple of days!
The shocks won't fit a stock tower, as you said, that uses the single stud, where these use a 1/2" bolt thru an eye, top and bottom.
I have several used TFI modules, maybe a new one (I'll have to look), but the relocation kit doesn't come with a new one.
Yes, I can ship the parts.
gclauson
Postby Gunnibronco » Sat Dec 02, 2023 1:27 pm
Thanks, I won't need the Bilsteins. I don't want to mess with the stock towers on my 72. Let them go to D&D72.
I don't need the TFIs I have one and a spare I think.
I'll message you my address and just let me know what the shipping is and I'll get you paid.
Return to Bronco Parts For Sale
