ARB Air Locker - RD117
Please post prices in your ad and delete or post up when your items are sold.
Postby B.O.B. » Thu Feb 22, 2024 11:46 am
I have an air locker for a 44 . Pt# RD117. Designed for 3.73 and down gears. May be able to use for higher ratio with the right gear set. Comes with a seal housing. Will need bearings. $600 obo.
B.O.B.
Re: ARB Air Locker - RD117
Postby TOOLMAN » Fri Feb 23, 2024 1:39 pm
By 3.73 and higher do you mean like a 3.50? If it works for 4.11 I would be interested.
TOOLMAN
Postby phyler » Fri Feb 23, 2024 4:06 pm
Probably needs the "thick" gears to work with 4.xx gears. If I didn't already own the gears and carrier, I'd be all over this.
Sent from my Pixel 8 Pro using Tapatalk
CCB Admin
Postby B.O.B. » Fri Feb 23, 2024 5:08 pm
That is correct. 3.73 , 3.50, etc. if you can find the thicker gear set then you would be in business. I have the rd116 which is for 3.92 and up, but that’s for mine.
B.O.B.
Postby TOOLMAN » Thu Feb 29, 2024 8:00 am
TOOLMAN
Return to Bronco Parts For Sale
