www.ColoradoClassicBroncos.com - View topic - intake torque setting's
It is currently Thu Nov 07, 2024 2:44 am
Reply to topic  [ 10 posts ]
Post intake torque setting's
Does anybody know what i should torque my new intake manifold to? and in what order? it's an edlebrok performer if that helps i'm also looking to getting new bolt's for the intake. any info would help thank's!!
matt. beer
Sun Mar 13, 2011 3:41 pm
Post Re: intake torque setting's
It's all on the last page of the instructions: http://www.edelbrock.com/automotive_new ... 0/2121.pdf
Sun Mar 13, 2011 3:50 pm
thank's viperwolf any ideas on the bolts?
Sun Mar 13, 2011 3:57 pm
...dont use crappy ones. ask me how i know
Mon Mar 14, 2011 3:05 pm
I used studs for the intake. Ace has them.
Mon Mar 14, 2011 5:53 pm
Oooh what happened with the crappy one's i'm always intersted in a good story!! popcorn
Mon Mar 14, 2011 7:48 pm
Images: 1
mat there is a chilton manual in top draw in garage by da refrig you r welcome to go get it . i think they are 5/16 and 20 to 25 ft lbs .if i remember right . use some sealer around matting surface
cheers . Molley
Mon Mar 14, 2011 8:01 pm
Images: 1
start toward middle and chris cross for pattern
again cheers Molley
Mon Mar 14, 2011 8:02 pm
Tue Mar 15, 2011 10:45 am
Sweet thanks for the info guy's. the intake is going back on tonight!! hopefully will have the motor running by the weekend!
Wed Mar 16, 2011 7:32 pm
32,803,587 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
