[phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4794: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4796: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4797: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4798: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) www.ColoradoClassicBroncos.com - View topic - 1/4 to1/2inch sheet metal/plating
]Checking if anyone has some good structural metal to build a truss. All the metal dealers are saying that I need to buy a whole sheet which is out of budget and heavy. Don't need much. Let me know, or if you know were to get smaller chunks.
Wed Mar 16, 2011 4:02 pm
cobshane
Re: 1/4 to1/2inch sheet metal/plating
Good to know thank you
Wed Mar 16, 2011 7:12 pm
K&K is a good source. I used them a lot when I lived up there. They may have what you need laying around.
