Oil Pan
Oil Pan
Postby PonyCorral » Wed Mar 09, 2011 9:42 am
Does anyone have any suggestions for a replacement oil pan and dipstick? The PO put in a chrome dipstick and cross threaded the oil pan.
74 Ranger
65 Fastback
PonyCorral
Re: Oil Pan
Postby 777mechanic » Wed Mar 09, 2011 10:11 am
is the motor in or out of truck if it's out , bring to me and i'll weld it and retap the hole . if not i have some sealant you could try as a temporary repair . just pm me .
777mechanic
Re: Oil Pan
Postby PonyCorral » Wed Mar 09, 2011 11:27 am
The motor is still in. I was planning on draining it and dropping the pan. What is the temporary fix, sealant?
74 Ranger
65 Fastback
PonyCorral
Re: Oil Pan
Postby 777mechanic » Wed Mar 09, 2011 12:02 pm
we use it to seal fuel tanks on airplane so it's resistant to everything . and when it goes out of date they just throw it away so i take it home
777mechanic
Re: Oil Pan
Postby akaFrankCastle » Wed Mar 09, 2011 12:06 pm
777mechanic wrote:we use it to seal fuel tanks on airplane so it's resistant to everything . and when it goes out of date they just throw it away so i take it home
Wish I could do that at work. Too bad 5.56mm never really goes out of date.
Re: Oil Pan
Postby OTTOMAN » Wed Mar 16, 2011 5:43 pm
PonyCorral wrote:Does anyone have any suggestions for a replacement oil pan and dipstick? The PO put in a chrome dipstick and cross threaded the oil pan.
If you are still looking, I have a pan and dipstick on my old motor sitting in my garage. was going to sell it to toms bronco parts but have just have not got around to it.
OTTOMAN
Re: Oil Pan
Postby Shawns Fords » Sat Mar 19, 2011 7:42 pm
Usually the pan threads don't even get damaged. you might just get lucky when you pull the pan and just need the new dipstick. the pans metal is a lot stronger than the tubes mounting nut just like the drain plug. Maybe another fancy schmancy dipstick, a gasket set, oil and filter, pull your pan and clean the threads up with a tap, and reassemble.
Shawns Fords
Re: Oil Pan
Postby PonyCorral » Sun Mar 20, 2011 8:45 pm
Sometimes it an easy fix! Thanks for the suggestion.
74 Ranger
65 Fastback
PonyCorral
Users browsing this forum: Google [Bot] and 1 guest
