Squatty stance fix?
Squatty stance fix?
Postby Cortez » Sun Mar 20, 2011 1:51 pm
My '67 is a bit squatty - maybe 3/4" lower in the back and I don't have a heavy spare tire or bumper. Looking to fix it and get recommendations...here's where I'm at.
I have 3.5" Duff coils up front, and 3.5" add-a-leaf in the back, but I don't know the brand of add-a-leaf. I'm wondering if I should go with the matching rear spring pack from Duff to solve the problem, or if I should maybe consider a 4" leaf pack to really get a level stance once I put the rear bumper and a 35" spare on it.
Comments??
Cortez
Re: Squatty stance fix?
Postby cobshane » Sun Mar 20, 2011 5:49 pm
It all depends on how much you want to spend or how low it is. You can try a heavier duty add a leaf. New leaf springs or a 1 inch lift block depending on how much it sags. I did use a 1 inch block on mine, its not ideal but it works till I can save some $krill for good lift kit.
cobshane
Images: 1
Postby ZOSO » Sun Mar 20, 2011 6:51 pm
Big bumper and winch on the front and it's fixed.
Postby airbur » Sun Mar 20, 2011 7:23 pm
New Wild horses 3.5" spring packs. They ride better than Duff's (in my experience) and you can get them with no shipping from the Hut:)
airbur
Postby Cortez » Sun Mar 20, 2011 8:30 pm
Eric - is that the 11 leaf pack? A better ride would be nice...she'll knock your fillings out right now if you ride in the back seat.
Cortez
Postby airbur » Sun Mar 20, 2011 8:37 pm
Cortez wrote:Eric - is that the 11 leaf pack? A better ride would be nice...she'll knock your fillings out right now if you ride in the back seat.
Yea....they are he 11 packs. I have the 2.5" versions and like them a lot. It's still a bit bouncy in the back but that's pretty typical for lifted Broncos. Mine stands with a rake towards the front but I actually prefer the look. With the soft top on you can't tell anyway.
airbur
Postby Cortez » Sun Mar 20, 2011 8:43 pm
cool - thanks
Cortez
Postby Jesus_man » Mon Mar 21, 2011 7:01 am
I've got a long leaf from a set of 5.5" leaf springs that you could try to swap into your pack. I was going to try that, but my driveshaft angle is already very steep, so it's better for me to go down in the rear. I paid $70 to have them shipped to me. Make me an offer if that's something you want to try. heck you could try it first and if it doesn't work, give them back.
Postby Cortez » Mon Mar 21, 2011 8:52 pm
Thanks for the offer J.D. - I'll give that option a little thought. The newer spring pack is a little attractive as they might be a softer ride.
Cortez
Postby Jesus_man » Tue Mar 22, 2011 6:30 am
Adding my leaf will only stiffen the ride, unless you can remove two leafs per side in place of this one. I am looking for options myself and I know how expensive new leaf packs are.
BTW - I called Alcan Spring and they would get me a new 6-leaf pack for $250 per side.
Postby airbur » Tue Mar 22, 2011 7:23 am
Jesus_man wrote:Adding my leaf will only stiffen the ride, unless you can remove two leafs per side in place of this one. I am looking for options myself and I know how expensive new leaf packs are.
$500 for a set of 6-pack leaf springs? Ouch!
airbur
Postby Jesus_man » Tue Mar 22, 2011 7:36 am
How well did that hold up? I have always been told that re-arcing them is a fairly temporary fix as they will settle back down.
Postby Jesus_man » Tue Mar 22, 2011 8:25 am
I wonder if drivetrain can replace just two leafs in my pack... I might have to give them a call. They did a great job on a driveshaft for me.
Postby BURNTFISH » Sat Mar 26, 2011 5:48 pm
Go with the WH ones they ride great. I have the 5.5 and love them. They flex great and ride real nice in the back. Big rear bumper with a 35 spare full cage and hard top. Call them up and see what they can do on a better price or shiping. They are great peps.
BURNTFISH
Postby Cortez » Sat Mar 26, 2011 6:11 pm
Yeah - I keep hearing good things about the 11 leaf packs
Cortez
Postby akaFrankCastle » Sat Mar 26, 2011 9:35 pm
BURNTFISH wrote:Call them up and see what they can do on a better price or shiping. They are great peps.
x2. Just ordered a stupid amount of brake lines from them. They wound up dropping just over 70 bucks (between 15-20% of the total) from my order.
Postby BURNTFISH » Sat Mar 26, 2011 11:37 pm
I got 2 winches from them free 2 day shiping and 10% off.
BURNTFISH
Postby airbur » Sun Mar 27, 2011 4:50 am
Bronco Hut carries Wild Horses suspension parts.....Melissa will beat their prices.
airbur
