crawlercreations wrote:Cut and re-weld! You will thank yourself later!
Oh and:
ZOSO wrote:the trick to use when you do this is to bolt the rear end in. with the spring perches just on the tube you can set the pinion angle. put a few nice tacks on it. pull it and weld er up.
Jesus_man wrote:You won't do that again!! Live and learn. The second set of pics look good!
akaFrankCastle wrote:Is it just me or does the rear look wider than the front now?
So, are you sitting with 8 lug wheels in the rear and 5s in the front?
coberlyshane wrote:akaFrankCastle wrote:Is it just me or does the rear look wider than the front now?
For now thanks for noticing. I do have a d 60 for the front. Just managing the fund for the front at this time. Work in progress as always.
akaFrankCastle wrote:Still looks great and some damn creative mods. A one of a kind fo sho!
