EFI parts - all of them.....long term plans
Postby Gunnibronco » Wed Mar 23, 2011 11:40 am
Looking into the long term..... I'd like to keep my eyes open for EFI stuff for my 74 - 302. I'm starting from scratch & would like to keep it cheap, but spend $ on new sensors & other service parts.
I DO NOT know as much as I should about this subject, if I'm missing a part or two let me know, if you can provide a bunch of these parts together, that would be best! I'm reading up as fast as I can. I'd like to get these in Colorado, especially the heavy stuff. Can pick up in Denver or GJ.
I'm interested in the following items:
Explorer Intake, upper/lower, fuel rails, TB, injectors, distributor - ideal version: w/fuel return line, w/o EGR - anything else I don't know about?
Mustang MAF, wire harness (although I think I'll buy a new one), ECU for manual trans
Explorer heads, or other highish performance head E7s?- assembled & new/clean/ready enough to run, I don't think I'm ready to shell out the bucks to fix a set up right now. Not real important, unless the price is really right. Really, don't even know what heads are on my Bronco, it was a fresh short block purchased by the PO.
RV camshaft good for this combo- again not high priority, may work around it.
Explorer Serp set up- again not that important
I'd buy an Explorer motor whole if its the best deal. I don't need the block, etc, but would welcome the offer.
My 302 is strong, I just want to EFI it & make it a bit stronger, I don't plan on going crazy.
Reply or PM me
THanks
Chad
Re: EFI parts - all of them.....long term plans
Postby cobshane » Wed Mar 23, 2011 10:02 pm
I would definitly buy a complete motor from craigslist or a junkyard buying all the sensors from a parts store new would almost as much as a used runnable engine
cobshane
Images: 1
Postby Gunnibronco » Fri Mar 25, 2011 11:29 am
Well that was easy. So far.
I was car-part.coming all the combos of parts/motors I could use & ran into a 96 Explorer 5.0 complete in Hotchkis, 88,000 miles, ran good when they parked it. $550.00 from serpentine to headers. I've put a deposit down & have to go pull it next weekend.
Still looking for a Mustang harness, MAF, TB????? Its time I brush up on how to move from here.
Chad
Postby Viperwolf1 » Fri Mar 25, 2011 2:35 pm
Gunnibronco wrote:Well that was easy. So far.
Chad
Use the explorer throttle body. It's bigger than the mustang.
Return to Bronco Parts Wanted
