It is currently Sat Sep 21, 2024 5:15 pm
[ 12 posts ] |
Front disk brakes, brake booster,rear seat?
totalchaos
Joined: Fri Mar 18, 2011 7:21 pm Posts: 167 Images: 0 Location: La Junta,Co
Also looking for front or rear disk brakes, brake booster, and a rear seat..for a 66 bronco with a dana 44 front, 9 inch rear
_________________ Im your huckleberry
Fri Mar 25, 2011 5:54 pm |
Re: Front disk brakes, brake booster,rear seat?
I'm in the middle of a disc install on my 44. If ya want, I'll shoot you all the part numbers and what not when I'm done so you can do it too. Planning a write up as well.
Fri Mar 25, 2011 8:26 pm |
totalchaos
Yes please do that would be very helpful thanks
Fri Mar 25, 2011 9:14 pm |
Will do. You guys have any good salvage yards down there in La Junta? If not, I'll keep my eyes open for another set of spindles and backing plates.
Fri Mar 25, 2011 9:17 pm |
totalchaos
Sat Mar 26, 2011 1:42 pm |
UPullandPay here in the Springs has been having a rough time with Chevy spindle selection. Found an oddball today while I was REpicking spindles. A 77 C10 4x4 with one 1/2 ton spindle and one 3/4 spindle. Had to go knock the covers off an auto-locking hub to get my second spindle. Anyhow, there is only one 1/2 spindle you could use left there. I do have two extra backing plates now though.
Sat Mar 26, 2011 2:35 pm |
totalchaos
Ok cool ill have to get with u on those..what rotors and calipers would I be looking at or what kind of vehicle would I pull it from?
Sun Mar 27, 2011 7:35 pm |
From everything I read: Spindles can come from 72-76 K5 Blazers and Jimmys and 72-77 10 and 15 Series GM trucks
Here's where I got all my info:
Sun Mar 27, 2011 9:22 pm |
Sun Mar 27, 2011 9:41 pm |
They just don't write them like they used to.
Sun Mar 27, 2011 10:04 pm |
cobshane
Sun Mar 27, 2011 10:10 pm |
totalchaos
Thu Mar 31, 2011 5:29 pm |
[ 12 posts ] |
