www.ColoradoClassicBroncos.com - View topic - Stock suspension...what would you do?
It is currently Fri Nov 08, 2024 4:35 am
Reply to topic  [ 14 posts ]
Post Stock suspension...what would you do?
So my stock suspension needs to be replaced, but I can't really afford a new lift kit at the present time (and I have more pressing bronco needs to address), so I was thinking of updating the stock suspension. What products/vendors would you use to do this in the most affordable way? I know WH has a stock suspension kit available, but even that is a little more than I would like to pay at this point, especially since this will only be temporary until I can purchase a lift kit.
I basically would like something that will allow me to use my bronco as a daily driver while I work on addressing other things on the bronco (hydroboost, front discs and new tires/wheels). I would say I am a year or more away from purchasing a lift kit.
Mon Mar 21, 2011 11:42 am
Post Re: Stock suspension...what would you do?
I guess a good question is what makes you think the suspension needs to be replaced? Do you have a busted leaf spring? Are the bushings shot? The reason I ask is that why pay double for a lift kit, save your money, do the things you want to first and do them right so you don't have to spend the money twice. If you are having some suspension issues (i.e. rough, bouncy ride), go get yourself a set of affordable shocks from Sears (Gabriel or Monroes) and deal with the rough stuff of the current components for the time being. The one problem that most people have (and I was one of them) is that they jump into upgrades too fast and don't do what is pressing rather than what is wanted. If I am you, I figure out what has to be done immediately, what needs to be done in 6 months and what I want done eventually. A list like that will save you time, money and headaches now and later down the road.
Take this for example, lets say that you want to go with a set of 35" tires and you go and install a 1" lift or stock suspension and then 6 months down the road you get the money to buy those 35s. You buy them but realize that they won't fit under a stock suspension so you have to buy the 3-5" lift kit. You just bought 2 kits when you should have only bought one. Or you put an ass load of money into a 4.5" suspension right now and have to run original sized tires on it for the next 6-8 months to save the money to buy those bigger tires. Make sense? I don't want to seem like I am shooting you out of the water, but build it right the first time so you don't have to rebuild it again later.
Mon Mar 21, 2011 1:43 pm
There is a rough, bouncy ride and my bronco sits with a mild lean to the passenger side. Also, my current tires (LT235/75R15) have significant dry rot. I completely agree with doing things right the first time, which leads me to believe I may not be able to make my bronco a daily driver as soon as I would like. It doesn't make much sense to get new shocks, coils, etc. and invest in a set of 31" tires now if I'm just going to lift it (plan is for 3.5" suspension with 1" body) and run 33" or 35" tires down the road, right? And based on what I've read in the forums it wouldn't be safe to run larger tires until I have a power brake system in place sooooo, that is where I need to start then by the looks of it.
Welcome to the world of early bronco ownership, right? Thanks for the input.
Mon Mar 21, 2011 5:00 pm
It sounds like you have a great plan for your Bronco - 3.5" Lift 1" Body and 35's. That is what dreams are made of. Keep watching Craigslist for what you need. I sold my Pro Comp 35's with Black Rims and Bought ProComp Polished 33's all in the same week. I love to search for 'procomp' and 'pro comp' just to see what is out there. I cannot blame you for wanting to drive your Bronco. As for the brakes, there are guys in the club running manual brakes and big tires.
Mon Mar 21, 2011 8:38 pm
I'm one of those guys. I've got 35s and manual drum brakes. It works, but I wouldn't want to daily drive it. I've had a few scary moments and leave lots of following distance. Do the front discs first, they'll be fine for a stock vehicle, and will probably be fine for bigger tires if you don't mind a heavy brake pedal. I'll second the suggestion for new shocks for a rough ride. Find some soft, cheap shocks and that should be a cheap way to help while you save up. I hear ya on big plans combined with a small budget.
Mon Mar 21, 2011 8:57 pm
I am running 37" tires on manual brakes. Fronts are discs rears are big drums. It will stop as quick as I want it to. Stopped faster than a newer compact blazer......his grill, headlight, core support, condenser and radiator were proof of it! As long as you are willing to deal with a harder brake pedal you will be fine!
Mon Mar 21, 2011 9:17 pm
BTW, if you don't have a hydroboost unit already check the pick and pulls. The one near 66th had at least 5 when I was there. Mine was $18.99.
Mon Mar 21, 2011 9:27 pm
Replacing the dry rot tires would be my priority
Mon Mar 21, 2011 11:39 pm
Tue Mar 22, 2011 9:12 am
I have a 66 that is drums all around and I have run 35 13.5 Krawlers and 37 Irocs. I even ran all the Ouray trails with a single master(I know how stupid that was). Mine was a daily driver for several years with manual brakes and if you push hard enough it will lock up all 4 tires.
Ask around for someones old stock springs. I might still have some of mine that would be free and ride real nice if I still have them. I ran 33's with a standard cut fender on my stock stuff for 2 years.
Sat Mar 26, 2011 7:01 pm
Sun Mar 27, 2011 6:31 am
Mon Mar 28, 2011 11:04 am
Mon Mar 28, 2011 11:11 am
I agree with others. Fix what needs fixed for sure and put off the creature comforts for a little while. Shocks are a good place to start, but make sure they are valved for the weight of a bronco or you'll still have a stiff ride. Maybe find some used. They could fix your rough ride. Springs aren't cheap, so you'd want to spend your money on what you want in the end, not what gets you by. The lean, while annoying, is also something that can wait. Smaller, stock sized tires can be had for fairly cheap if you're looking hard and not super picky. There are businesses who specialize in used tires if you can't find anything on your own. Disc brakes are a smart upgrade as well. However, manual brakes aren't that bad. I run a manual setup with disc/disc. Don't know why it works, but it does. Enough that boosting my system isn't even on my upgrade list.
You also don't need a lift "kit" if you're willing to do some looking on your own. Often times you can come up with you own for much cheaper, especially used if it fits your bill. Suspension has come a long ways and it seems like in the last 8 yrs or so, you can get better riding springs, so you don't want old lift springs.
Seems like the big three items that are keeping your bronco off the road are brakes, tires, and a bouncy ride. Tires and the bounciness are very easy to tackle. Brakes are a little more involved in both time and money, but is an upgrade that will benefit you no matter your future plans for the rig.
Tires:
http://denver.craigslist.org/pts/2290141494.html
http://denver.craigslist.org/pts/2288669002.html
Mon Mar 28, 2011 1:42 pm
32,811,920 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
