www.ColoradoClassicBroncos.com - View topic - modification mishap
It is currently Thu Nov 14, 2024 10:14 am
Reply to topic  [ 19 posts ]
 modification mishap
Images: 1
 modification mishap
2011-03-24_22-18-25_561.jpgSo im putting in a dana 70d and I am paying to much attention to how the d 70 leaf spring mounts are setup that I weld them in at the exact same pinion angle position as they were already mounted as it was stock.
Not looking at how it was angled on the 9 inch. Just going off the backing plate mount flat spot On the d 70 and there mounted flush to that flat spot. And the 9 inch is mounted at a angle to its flush point on the backing plate mount.
So I set the axle on the leafs and guess what, my pinion is facing to the ground. S#&%*#&$@$*%. Yeah I think that's how it went. So for you guys doing axle mods what do you think. should i chop the mounts off again or use pinion angle shims. I would have to use 3/4 inch shim to get were I need it. And those blocks will be gone too.
Thu Mar 24, 2011 11:09 pm
Post Re: modification mishap
Cut and re-weld! You will thank yourself later!
Oh and: worthless
Thu Mar 24, 2011 11:12 pm
Images: 1
Thu Mar 24, 2011 11:18 pm
Thu Mar 24, 2011 11:22 pm
Images: 1
I can't write and send pics at the same time with my stupid phone. It tells me its smart but I would differ. I just needed an extra push to cut them again. I know what I should do but I was also thinking about being lazy. Yeah your right, they need redone.
Thu Mar 24, 2011 11:24 pm
Images: 1
Good thing I bought a refill of plasma for my cutting tool. Stuff comes in handy. Alright I guess the sooner on the road not better.
Thu Mar 24, 2011 11:33 pm
Images: 1
Going on the redo keep you all posted
Sat Mar 26, 2011 2:11 pm
the trick to use when you do this is to bolt the rear end in. with the spring perches just on the tube you can set the pinion angle. put a few nice tacks on it. pull it and weld er up.
Sat Mar 26, 2011 5:35 pm
Images: 1
Sat Mar 26, 2011 10:09 pm
Images: 1
took your advise zoso and set the perches on and set the full weight of the truck on the axle, pitched the pinion to were would be at its best angle for the axle being able to flex around. tacked it and then squirted metal all around. sitting great. now building up some plates.
i also found nice brackets from ebay, 3/16 thick. $26.00 including shipping. comes with 20. good price with lots of uses. made for 1 1/2 tubing but can always be modified for what ever.
Sun Mar 27, 2011 10:53 pm
Images: 1
pic of those brackets i also have some motor mounts if anyone wants. for a 302. just need finisshed welding. i can do if wanted. $10 for them.
Sun Mar 27, 2011 11:02 pm
You won't do that again!! Live and learn. The second set of pics look good!
Mon Mar 28, 2011 1:44 pm
Images: 1
Mon Mar 28, 2011 3:08 pm
Images: 1
Its done its finally done. All working great. Just need to do some fender slashing.
Sat Apr 02, 2011 7:23 pm
Is it just me or does the rear look wider than the front now?
So, are you sitting with 8 lug wheels in the rear and 5s in the front?
Sat Apr 02, 2011 8:54 pm
Images: 1
Sat Apr 02, 2011 9:08 pm
Images: 1
Sat Apr 02, 2011 9:10 pm
Still looks great and some damn creative mods. A one of a kind fo sho!
Sat Apr 02, 2011 9:21 pm
Images: 1
Sat Apr 02, 2011 10:16 pm
32,874,706 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
