coberlyshane wrote:You can use a 3/4 round to a 36 spline ujoint just cut the shaft and weld the smooth part in. I got one at ontrack off santefe road.
coberlyshane wrote:coberlyshane wrote:You can use a 3/4 round to a 36 spline ujoint just cut the shaft and weld the smooth part in. I got one at ontrack off santefe road.
Can't remember for if it was 36 spline. You might want to count.
jtsbronc wrote:I think it is 13/16" x 36 spline on that box.
coberlyshane wrote:jtsbronc wrote:I think it is 13/16" x 36 spline on that box.
Ya your right it is 13/16. That's what you need. Alot easier than swapping out a column.
totalchaos wrote:I about have all my steering parts and i think i found that knuckle on ebay but it say 13/16 3/4 by 36 tooth would that be the right one??
coberlyshane wrote:totalchaos wrote:I about have all my steering parts and i think i found that knuckle on ebay but it say 13/16 3/4 by 36 tooth would that be the right one??
That's the one! The 13/16 is the box side with splines, and the 3/4 is the smooth side for were you cut the steering shaft.
