www.ColoradoClassicBroncos.com - View topic - dom steering setup (stone crusher style)
It is currently Sun Sep 22, 2024 5:32 am
Reply to topic  [ 15 posts ]
Post dom steering setup (stone crusher style)
looking for a knuckle over with heims steering for a 75. Dom a must
trei 7-936-0791
Thu Apr 07, 2011 7:27 am
Post Re: dom steering setup (stone crusher style)
Good luck finding a used setup. I went this route:
http://classicbroncos.com/forums/showth ... p?t=179150
Thu Apr 07, 2011 7:55 pm
So I Called HCP4x4 today and was quoted over $325 for the entire set up.Heims, DOM, inserts, Wow I might as well go with a already built one
Thu Apr 07, 2011 8:47 pm
I wrote up the article I posted. Total cost was about $225. Any particular reason why you're set on heims?
Thu Apr 07, 2011 9:11 pm
No just looks cool. Lol. I will check out your write up again
Thu Apr 07, 2011 9:25 pm
Heims really suck on the street. Do the set-up justin has. I also run that on my 79 and am happy with it.
Fri Apr 08, 2011 6:18 am
Fri Apr 08, 2011 8:34 am
Crawler what would you charge to make me a setup??
Fri Apr 08, 2011 8:45 am
Don't mean to stirpot but I also thought heims are more dangerous in a street application. My understanding is that a TRE does not fail the same way a heim does. Is this not true?
My Personal Website -
Fri Apr 08, 2011 12:01 pm
good ? and Im glad you asked it cuz I dont friggin know LOL
Fri Apr 08, 2011 12:17 pm
Fri Apr 08, 2011 2:15 pm
Fri Apr 08, 2011 7:13 pm
Images: 1
i 100% agree with crawlercreation , i have run rod ends / heim joints on trac bar all steering comp ,rear traction bar , hyd assit ram, throttle cable .ect ,just to name a few spots that they live on Molley . and she has good road maners and very responsive steering . none of the mounting holes have worn out , but just like everything else rod ends will wear out if you use and abuse them ! p.s. aircraft also use rod ends . my 2-1/2 cents
Fri Apr 08, 2011 8:13 pm
I like heims just fine if they're quality. I just didn't want to go that way due to availability. I can get a GM rod end anywhere in BFE for $25. Granted, it probably won't be the Moogs I'm running, but good luck finding a heim. I also like the fact that I can grease them and at least flush some of the gunk out.
Fri Apr 08, 2011 10:50 pm
I can onLy say this on the subject, a tie rod end will give you more range of motion than a standard heim joint,
Fri Apr 08, 2011 11:05 pm
32,312,949 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
