www.ColoradoClassicBroncos.com - View topic - Whats this thingamabob?
It is currently Fri Nov 15, 2024 1:34 pm
Reply to topic  [ 10 posts ]
Post Whats this thingamabob?
I see this in the ignition circuit but don't know what it is.. The ceramic is cracked on one side.
thanks
Brett
Sat Apr 09, 2011 6:24 pm
Images: 13
Post Re: Whats this thingamabob?
wow now that sure is a thingamabob dang near thinnnngggggajig
old school resistor idk spent n hour in my bronco i dont have one any where sorry maybe a way to connect the 2 since they didnt have shrink wrap or that was all they had lieing around in there garage?
TRAVIS HOYLE
Sat Apr 09, 2011 6:45 pm
Profile YIM WWW
That's your Ballast resistor, it controls the amount of voltage going to your coil so you wont fry your ignition system.
Sat Apr 09, 2011 6:57 pm
Sat Apr 09, 2011 7:09 pm
Yes, I would use Car Quest or NAPA before going elsewhere.
Sat Apr 09, 2011 8:39 pm
You need about 1.2 ohms.
Sat Apr 09, 2011 8:40 pm
Images: 13
i guess ill fry mine i dnt have ne f theses
TRAVIS HOYLE
Sun Apr 10, 2011 8:17 am
Profile YIM WWW
Sun Apr 10, 2011 8:27 am
Good point to remember, many model Fords had the resister wire instead of a ballast resister. But when that wire fried, a lot of people would install the ballast in its place and run a regular wire. It is a lot easier to change the ballast resister on the firewall/fenderwell than the wire. Something to remember when your working on the section of your project.
Sun Apr 10, 2011 11:14 am
All EB's had the resistor wire. It's a common thing to burn up if you leave the ignition switch on too long without the motor running. Easy fix is to replace the resistor wire with standard wire and add te ceramic resistor.
Sun Apr 10, 2011 11:48 am
32,884,704 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
