EFI ?
EFI ?
Postby B.O.B. » Fri Apr 15, 2011 5:21 pm
Almost done doing the conversion just trying to figure out how to run the hoses to the heater core and back and have the stock heat control knob work. Any suggestions would be appreciated and pictures would be outstanding. thanks a bunch peeps.
B.O.B.
Re: EFI ?
Postby Viperwolf1 » Fri Apr 15, 2011 6:29 pm
Autozone #4336
Re: EFI ?
Postby Entourage » Fri Apr 15, 2011 8:58 pm
Hey Viper - is that the 800 LB. toy that you and 777 are working on?
Re: EFI ?
Postby Viperwolf1 » Fri Apr 15, 2011 9:30 pm
No, this is the toy that sits under my hood.
Re: EFI ?
Postby rtreads » Sat Apr 16, 2011 7:50 am
..um. hey viper, need more info on this "toy"
rtreads
Re: EFI ?
Postby Viperwolf1 » Sat Apr 16, 2011 11:22 am
You've seen it. Just a '89 mustang block, decked and line bored. Stock crank, deburred. Stock rods, polished beams. Balanced rotating assembly. Stock HO cam, advanced 4 degrees. Stock forged pistons. AFR 165 heads, slightly milled. Compression ratio is about 9.7:1. Explorer intake manifold, serp system, oil pan and oil cooler. 19 lb injectors and A9P ECU. It's an economy engine, gets 30% better mileage than the stock 302/2bbl ever did and has 2 or 3 more horsepower.
Re: EFI ?
Postby Rox Crusher » Sat Apr 16, 2011 4:42 pm
Viperwolf1 wrote:You've seen it. Just a '89 mustang block, decked and line bored. Stock crank, deburred. Stock rods, polished beams. Balanced rotating assembly. Stock HO cam, advanced 4 degrees. Stock forged pistons. AFR 165 heads, slightly milled. Compression ratio is about 9.7:1. Explorer intake manifold, serp system, oil pan and oil cooler. 19 lb injectors and A9P ECU. It's an economy engine, gets 30% better mileage than the stock 302/2bbl ever did and has 2 or 3 more horsepower.
oh so humble..................don't doubt your specs, all I know is that thing sounds awesome when you stomp on it
Re: EFI ?
Postby B.O.B. » Sun Apr 17, 2011 5:44 am
Where does the Control for the temp go? Are putting it on the reyurn line back to te pump? Is there no need to use the bottom tube either? Thanks Viper for all your help.
B.O.B.
Re: EFI ?
Postby Viperwolf1 » Sun Apr 17, 2011 8:29 am
B.O.B. wrote:Where does the Control for the temp go? Are putting it on the reyurn line back to te pump? Is there no need to use the bottom tube either? Thanks Viper for all your help.
Sorry, I should have explained a little. I used the same hose for both tubes. You'll need to trim the hoses a little to get them to fit. Then just cut one where you want to install the valve. I put the valve on the return side because it fit better.
Re: EFI ?
Postby Shawns Fords » Sun Apr 17, 2011 10:30 am
My 64 F100 has the same type of control valve. You can see it in this pic right on the fenderwell. This is the same way it was set up from the factory 223 but hooked up to my 460. right in front of the battery on the passenger fenderwell, behind the MSD box. Image
Shawns Fords
Re: EFI ?
Postby Viperwolf1 » Sun Apr 17, 2011 10:40 am
69 Bronco 69 wrote:My 64 F100 has the same type of control valve. You can see it in this pic right on the fenderwell. This is the same way it was set up from the factory 223 but hooked up to my 460. right in front of the battery on the passenger fenderwell, behind the MSD box. Image
So that valve has a 90 in the tubing? That could work well.
Re: EFI ?
Postby Shawns Fords » Sun Apr 17, 2011 10:57 am
Yeah, I didnt get a close look at the Bronco but its straight if I remember right.
Oh and just a thought. Its good to open that valve now and then in the summer to let fresh coolant get circulated through there.
Shawns Fords
Re: EFI ?
Postby B.O.B. » Mon Apr 18, 2011 7:08 pm
How are doing the front. I am sure the top goes to the water pump but doesn't that leave the bottom one open with no where to go.
B.O.B.
Re: EFI ?
Postby Shawns Fords » Mon Apr 18, 2011 7:12 pm
BOB one runs straight into the heater core, then the other line runs through the control valve then into the core. I would run the one from the water pump into the valve then into the core and return straight back. I think that is what you are asking.
Shawns Fords
Re: EFI ?
Postby Viperwolf1 » Mon Apr 18, 2011 7:15 pm
B.O.B. wrote:How are doing the front. I am sure the top goes to the water pump but doesn't that leave the bottom one open with no where to go.
One goes to the pump and the other goes to the intake manifold.
Re: EFI ?
Postby B.O.B. » Tue Apr 19, 2011 7:14 pm
It think my typing was faster than me thinking when I asked the last question. Went and looked and answered my own question.
B.O.B.
