www.ColoradoClassicBroncos.com - View topic - Wont run after Explorer serp and typhoon intake swap FIXED
It is currently Sat Nov 16, 2024 3:29 pm
Reply to topic  [ 61 posts ]  Go to page Previous  1, 2, 3  Next
Post Re: Wont run after Explorer serp and typhoon intake swap.
I would have to assume that it is on the comression stroke. The balancer reads 0*, the #1 piston is all the way up, and the distrubitor is pointing at the #1 wire.
If it was 180* out, it wouldn't run at all.
Fri Apr 15, 2011 7:12 am
Images: 1
You are #1 on compression stroke, right.
Fri Apr 15, 2011 7:20 am
Images: 1
Fri Apr 15, 2011 7:26 am
Images: 5
Just throwing some basics out there that got me beings i had not always worked on Fords. Double check the distributor firing order is set up counter clockwise and that the right and left banks are not odd and even but 1 - 4 and 5 - 6. Just some things to check.
After looking at the video a bunch it looks like all this is correct.......Have you checked spark on each wire and plug?
Fri Apr 15, 2011 8:56 am
My firing order is 1-3-7-2-6-5-4-8.
I have been over it about 8 times... but I am going to look it over again tonight and make sure there is a positive connection at each plug,
Fri Apr 15, 2011 11:52 am
make sure you OHM out each wire and that none of your plugs got cracked/broken when going back together. If your ignition checks out all good I would do a compression test on all 8 cylinders.
Fri Apr 15, 2011 12:19 pm
What's the word Ryan?
Fri Apr 15, 2011 10:32 pm
My guess is still in the garage, burning the midnight oil and trying desperately to make it to breakfast tomorrow. Wishin him luck.
Fri Apr 15, 2011 10:57 pm
Images: 5
i
Fri Apr 15, 2011 10:58 pm
Well by now you are all enjoying a nice breakfast and looking at a BUNCH of really cool broncos.... maybe next time for me.
I will do the KOER test today. Then switch back to the 19# injectors to see if that helps.
Sat Apr 16, 2011 8:15 am
Sat Apr 16, 2011 9:20 am
Ryan,
Give me a ring if you need me to come over and take a look at it.
Sat Apr 16, 2011 12:08 pm
I went over and took a look at Ryan's engine. We found the source of the problem. Something I never saw before. Kind of like a combination exhaust and vacuum leak. Hopefully he'll post some pics.
Sat Apr 16, 2011 6:24 pm
Glad to hear you guys figured it out.
Sat Apr 16, 2011 6:29 pm
Sat Apr 16, 2011 6:56 pm
EGR hole at the bottom of the upper was cast all the way through to the intake plenum, not just into the EGR passage to the throttle body flange. Kind of like a 20mm vacuum leak and exhaust leak.
Sat Apr 16, 2011 7:08 pm
i told phil that was the problem and he steals all my thunder , hahahaha
Sun Apr 17, 2011 9:04 pm
Nice job getting it diagnosed and fixed. It is nice to have that many EFI Experts in the club. Congrats and a nice way to end the weekend!
Sun Apr 17, 2011 9:25 pm
Images: 5
Was it fixable, or will he need a new intake?
Sun Apr 17, 2011 9:28 pm
phil said he just needs to tap and plug the hole in the intake and all should be good.
Sun Apr 17, 2011 9:34 pm
Images: 1
Anyone else ever run into this problem. Was the egr deleted, or stuck open? Let's see pics.
Sun Apr 17, 2011 10:15 pm
Those aluminum termites get in to the darnedest places.
Sun Apr 17, 2011 10:16 pm
Sun Apr 17, 2011 10:53 pm
So I am finally getting pics postes of the problem.
When I bought this intake, my brother and I looked it over saying; wow, its made much better than we had expected. We both expected needing gasket matching and various other things to clean it up. Well, it was clean enough. Though it did have a hole above the exhaust port for the EGR gasses. We were like, that doesn't look right, but its a cast hole and must be there intentionally. NOT the case. I just happened to be talking about weird issues while Phil was doing a compression test to make sure it wasn't a stuch exhaust valve (THANK YOU PHIL!!!). I had mentioned the hole, and he just stoped and looked at me with a really weird look on his face. We pulled the intake piping, and opened the TB and I showed him. He started laughing and couldn't believe what he was seeing. So turns out there was NOT suppesed to be a hole thru the 2nd wall of the intake into the main runner. I had to buy a 1/2" Pipe tap to get a plug big enough to plug it. Its all done now and RUNS.
Thanks for all of your help!
And THANK YOU PHIL!!!
Tue Apr 19, 2011 8:09 am
New video, new video, new video...
Tue Apr 19, 2011 8:47 am
Images: 1
Tue Apr 19, 2011 9:08 am
...your telling me? Hey its CHINA!!
Tue Apr 19, 2011 9:38 am
That plug fits nicely. I've searched the web for similar problems with that intake but couldn't find anything. Maybe it's one of a kind.
Tue Apr 19, 2011 11:32 am
Tue Apr 19, 2011 11:36 am
Tue Apr 19, 2011 11:40 am
32,887,887 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
