It is currently Sat Sep 21, 2024 5:18 pm
[ 3 posts ] |
Coolant outlet for Edelbrock Performer
Install of the new intake and carb is on hold at the moment. Looking for a 90* coolant outlet for the front of my intake. This would be the piece where the coolant exits the intake and heads to the heater. Looks to be about 1/2" OD. I'd pull the one from the old intake, but the OD is smaller on that one. Looks to be about 3/8"
Wed Apr 20, 2011 6:53 pm |
Re: Coolant outlet for Edelbrock Performer
Brass fitting at ACE hardware or similar should fix you up. Should just be pipe thread in the intake and a bard fitting on the end for the hose. I found one for my last intake at ACE hardware.
Wed Apr 20, 2011 7:38 pm |
Word. Didn't even think to check ACE.
Wed Apr 20, 2011 8:03 pm |
[ 3 posts ] |
