It is currently Sun Nov 17, 2024 2:44 pm
[ 4 posts ] |
9" yoke/ujoint questions
Alright, this is buried inside my axle swap build thread, I wanted to get more eyes on this than might be watching the other thread. I need to get this project running again, soon.
I'm swapping in a 79 Bronco Ford 9". The yoke is for the 1330BigCap (w/1-1/8" caps). My driveshaft has the stock 1310 ujoint. There is no 1310x1330BC conversion u-joint, that I've found. If there is one, please let me know.
Since (if) there is no conversion u-joint, replacing the yoke is my only option. I'll replace the driveshaft when I swap t-cases, maybe going auto tranny too. This will be a while, probably more than 1 year.
What does the length of yoke matter? I'm confused. On ringpinion.com, there are 2 lengths noted 4" & 5". Some of their listings show the 4" for Daytona pinion support, other don't. I don't have the yoke in front of me, but I think its 4" (I don't think its a Daytona pinion support- its factory). None of the other vendors list lengths. The length measurement is what Carquest had trouble matching. Can I use a 5", if the old one is 4", or vise/versa? I don't see why not.
Since yokes are expensive, and I expect to upgrade driveshafts in the future, what size yoke should I buy?
Option #1: Use a 1310 yoke, the advantage, all u-joints on the truck are 1310. The disadvantage, when upgrading driveshaft, I'll probably buy a new yoke, again. I could steal one (right length?) off my old 9", but want I to sell it complete, so that isn't permanent.
Option #2: Use a 1330 yoke, with normal cap sizes, not the 1-1/8" caps. I'm not sure, but I think I can get a normal 1330 yoke. Disadvantage, it doesn't seem the 1330 is much of an upgrade to the 1310, a little wider, but the same size caps. Advantage, I already bought & installed a 1310x1330 conversion joint for my driveshaft.
Option #3: Use a 1350 yoke. Advantage, I think this is the joint size I'll end up with after upgrading the driveshaft. I think there is a 1310x1350 conversion u-joint. I know this won't be much stronger than the 1310, but saving $100.00 in the future......
Any other ideas are appreciated.
Chad
Sun Apr 24, 2011 7:23 pm |
Shawns Fords
Re: 9" yoke/ujoint questions
I dont know how well your parts houses are equipped out in Gunnison but what I did to get me by on my 64 F100 to make the shaft I had work with the combo I have. I spent about 2-3 hours with a Feller at Havana auto parts on East Colfax (NAPA) who is no longer working there but was a great parts guy. we found a universal joint that had offset caps to allow my junkyard shaft fit up to the Ford 9" yoke. Its the strangest thing ive seen but it works until I can get a new shaft made for it. Its a Big block C6 going to a ford 9 with a shaft from a 78 Grenada. I guess what im saying is, there has to be a universal joint out there to get you buy until you finish the other conversions. Might not be a simple tack in the hills though.
Sun Apr 24, 2011 7:56 pm |
There is a conversion joint. I have a 1310 yoke on my d44 and a 1330 shaft. Took me a while to find one. got it at autozone. I'll get the part number for you tomorrow.
Sun Apr 24, 2011 8:22 pm |
Sun Apr 24, 2011 8:46 pm |
[ 4 posts ] |
