It is currently Tue Oct 08, 2024 12:41 am
[ 7 posts ] |
Stump the Bronco Chump Friday Edition
Re: Stump the Bronco Chump Friday Edition
Throttle linkage
Fri Apr 29, 2011 6:00 am |
BNC04
clutch rod linkage at the pedal (assuming a manual) Brett
Fri Apr 29, 2011 6:10 am |
BNC04
I have actually used a Bobby pin for one of those in the past. My grandmother was with me at the time and I had to pull onto the raised median at an intersection.. I'll never forget the look on her face! It was at least 20 years ago and the first Bronco I ever had.. Glad the "doo" she was wearing then, required bobby pins.
Brett
edited to add,, time to throw some cotter pins into the "possibles" bag I am putting together.
Fri Apr 29, 2011 6:22 am |
I used to keep a few finish nails in the glovebox for shifter linkage replacement pins. Probably not the best replacement, but it worked in a pinch.
Fri Apr 29, 2011 10:32 am |
Vise grips worked for me when it came apart while wheeling.
Fri Apr 29, 2011 10:38 am |
I'm gonna say the clutch linkage pin broke.
I like this 24 hr wait thing.
Sat Apr 30, 2011 7:16 am |
I had the same thing happen on a dirt road. As I pulled up to the highway, I stopped & "stole" some bailing wire off a mailbox & fixed the problem.
Chad
Sat Apr 30, 2011 7:27 pm |
[ 7 posts ] |
