www.ColoradoClassicBroncos.com - View topic - Fuel Gauge
It is currently Mon Nov 18, 2024 10:49 am
Reply to topic  [ 9 posts ]
 Fuel Gauge
Post Fuel Gauge
I am now trying to get my fuel gauge to work. I just replaced the switch on the dash, and now the gauge just barely moves stays just below empty on both tanks. Now I'm wondering if the sending units are bad in both tanks. I don't think it's the gauge, because I do get movement on it. I'm not really sure how to check it though. Anybody else had this problem.
Sat Apr 30, 2011 8:24 pm
Images: 5
Post Re: Fuel Gauge
If your fuel gauge, Oil pressure and heat all read low or not at all, it may be the gauge voltage regulator.
Sat Apr 30, 2011 8:43 pm
Post Re: Fuel Gauge
you can usually ground your sending unit wire and it will make the gauge read full. I like to use a gauge tester because you can control the resistance to verify it has the proper resistance reading per required specs for the particular gauge. but grounding that wire will verify if it is the sender or wire or gauge.
Sat Apr 30, 2011 8:45 pm
Post Re: Fuel Gauge
How do you ground your sending unit?
Sat Apr 30, 2011 9:09 pm
Post Re: Fuel Gauge
Sat Apr 30, 2011 9:29 pm
Post Re: Fuel Gauge
Grounded out the sending unit and it pegs the gauge to full. I'm assuming that the sending unit is bad?
Tue May 03, 2011 2:29 pm
Post Re: Fuel Gauge
Either bad or you are out of gas in both tanks laughing2
Tue May 03, 2011 2:45 pm
Post Re: Fuel Gauge
or the ground at the connector is no good.
Tue May 03, 2011 2:47 pm
Post Re: Fuel Gauge
I just filled up the other day to make sure I eliminated the out of gas, and the ground seems good. The gauge just comes up to under empty when the key is turned on.
Tue May 03, 2011 3:03 pm
32,897,002 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
