It is currently Tue Jun 25, 2024 11:07 pm
[ 10 posts ] |
RickGyver
Joined: Sun Feb 27, 2011 12:39 pm Posts: 21 Images: 0
![Post Post](./styles/acidtech/imageset/icon_topic_latest.gif) O.K.,,,, I screwed up!
Last year I was at Penrose watching my boys doing that nasty Independence canyon. I flat towed my Bronco home behind the motorhome. Got home to Centennial and realized I had forgotten to unlock the front hubs! ![banghead banghead](./images/smilies/Headbang.gif) I grenaded the tranny (c4) but not sure about damage to the transfer case. Any ideas what damage may have been done to the Tcase? I plan on dissing case. Needs seals anyway. thx
Sun May 01, 2011 6:51 pm |
![Post Post](./styles/acidtech/imageset/icon_topic_latest.gif) Re: O.K.,,,, I screwed up!
Tcase is probably ok. The front output shaft turning slings oil around inside it.
How did it hurt the C4? Was it in neutral with the tcase in gear?
Sun May 01, 2011 7:00 pm |
Yep, T-case is likely fine.
Mon May 02, 2011 7:22 am |
RickGyver
The c4 tranny was in neutral but took out all fwd gears. I still have reverse. This will be the fourth time that this tranny has broken so it's now a donor tranny! My neighbors are starting to to look at me funny! I have had broncos for a long time and was always under impression that you cannot flat tow w/ tcase in neutral. I've always dis'd the driveshaft. Let me know how it went after YOU try it!!
Mon May 02, 2011 7:04 pm |
Shawns Fords
Donor the tranny to me? :-D
Mon May 02, 2011 7:31 pm |
Mon May 02, 2011 8:37 pm |
777mechanic
hey can i help also phil would like to see what messed up inside after being towed like that ?
Tue May 03, 2011 8:16 am |
GMAN
I ruined mine after a breakdown flat towing....ruined the case let me know if you need help getting that fixed GMAN
_________________ GMAN 70 Roadster 347 burnt orange
Wed May 04, 2011 3:38 pm |
RickGyver
Guys,,,, I'm just getting the Bronco in the garage to replace the tranny with an EFI and built C4. . I was wondering if anyone has pulled the engine with the t-case and tranny hanging off the back. Sounds a little like that monkey "sitting" on a football! Send me a PM if you'd like to stop by. My garage is heated!
Sat Nov 12, 2011 10:57 am |
RickGyver
Sat Nov 12, 2011 11:34 am |
[ 10 posts ] |
Users browsing this forum: Google [Bot] and 3 guests |
