It is currently Sat Nov 23, 2024 12:26 pm
Reply to topic  [ 2657 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8, 9, 10 ... 89  Next
Tue May 03, 2011 6:55 pm
Images: 13
these r 2 pictures of it finally done well i am (with in the next 2 week) putting a dual one red and one yellow optima battary with dual tray behind the driver side so winch wireing will have to wait till then i suppose lol
TRAVIS HOYLE
Wed May 04, 2011 3:02 pm
Profile YIM WWW
Finished installing the up front floor pans and got them primered today. I hope to get the gas tank back in this weekend and get it out of the garage. Then maybe I can start the herculiner!! JP
74, MONEY EATER
Thu May 05, 2011 9:12 pm
Dropped off for paint and bedliner. My excitement is nearly uncontainable!
My Personal Website -
Thu May 05, 2011 9:40 pm
Thu May 05, 2011 11:18 pm
Fri May 06, 2011 8:49 am
I test fit and modified the fiberglass interior panels from Jay. Only needed slight modification due to the multiple coats of Herculiner. They fit like a glove. A big Thanks to Jay for the great addition.
Test fit the Corbeau seat adjusters on the family cage seat mounts. Been puting this off for weeks but they fit perfectly and huge relief - not sure what i would do if they were even a 1/4" off. The seats are going to work out perfect. A big shout out to the designer and craftsmanship of the cage builder in Utah.
Fri May 06, 2011 9:01 am
Thanks Chad.Glad they worked out .I'm currently working on some other interior pieces.Should have something to show soon.Can't wait to see your ride in person.JGZ
Fri May 06, 2011 10:26 am
Meeting up with Dana from the Bronco Hut today to pickup a new washer resevoir and motor. Exciting stuff! ;)
Fri May 06, 2011 10:30 am
Thanks, PM sent.
Fri May 06, 2011 12:46 pm
my front shaft is done, will get it picked up next week, then I can focus on my brakes, Been contemplating Booster options. I am liking the Hydrobooster setup but dont have the availability of salvage yards nearby. Maybe I could use a vac booster system for now and work on the hydro as time goes by. I think it is frankcastle that did the writeup on it?
Suggestions please?
Fri May 06, 2011 11:41 pm
Actually, Sbolt19 has a write up on here, sort of, of a hydro install. I'm still in perpetually in the middle of mine. But, depending on how much coin you want to drop, you can pick up nearly everything you need from Advanced or AutoZone.
Sat May 07, 2011 12:24 am
Sat May 07, 2011 2:10 am
Installed the new reservoir and motor and the jets work perfectly:). Had to fix a leak where the hose connects to the motor but that was it.
I did learn that you can't fill the tank up to the top as the lid is attached to it using a hole. Started pouring out until it dropped below that level.
Sat May 07, 2011 5:18 am
Got the rear tank re-installed and 5 gallons of fuel and it runs great, although a little rich. The fuel gauge works to!!!! JP
74, MONEY EATER
Sat May 07, 2011 2:14 pm
replaced leaking rear axle seal
tightened up oil sending unit in an attempt to stop oil leak
Sat May 07, 2011 2:29 pm
Replaced the driver side ball joints. Next up is passenger side.
Sat May 07, 2011 3:54 pm
Images: 13
lol i did nothing, but because my wife is always trying to find her gifts n what not, ma and the kids used the tuffy glove box to hold her 2 gifts lol
TRAVIS HOYLE
Sat May 07, 2011 7:54 pm
Profile YIM WWW
Did the 'Alice' parking light upgrade with 1966 clear parking light lenses in my 1973 grill.
Sun May 08, 2011 7:39 pm
Completely stripped out the interior.....seats, carpet, seat belts, tunnel cover, etc. in prep for family cage. Coated the carpet with Dawn and power washed all the pieces.
Sun May 08, 2011 7:53 pm
Pulled the top off last night and hope to start herculining the interior today!!
74, MONEY EATER
Mon May 09, 2011 11:32 am
Mon May 09, 2011 12:21 pm
Got some great advice from Entourage Thanks for the hints, I have both front floor pans completed as of 1534 today and the underside where I placed new metal. I already had golf tees in place, but the xylene was a good idea, it came off my brushes pretty easy with warm soapy water and a little elbow grease, gloves are a must as this crap is messy (my garage floor looks like a roofing company went crazy with the tar). I will start the tunnel and bed tomorrow. This is a time consuming adventure. JP
74, MONEY EATER
Mon May 09, 2011 3:42 pm
Mon May 09, 2011 6:37 pm
Watched as it was loaded onto a flatbed and towed down the street and out of sight. On it's way to Greeley for family cage:)
Mon May 09, 2011 8:08 pm
dropped it off for some carb work (not my cup of tea)
Mon May 09, 2011 8:12 pm
Here are the pictures. I did put 3 coats down, I plan on not touching or stepping on it for a couple of weeks till it sets good. I will start on the pack. I used almost 1/2 a gallon, I did do the underside on the new metal. JP
74, MONEY EATER
Mon May 09, 2011 9:21 pm
Yesterday worked on my bumper/winch plate:
Today, hope to reassemble and install rear leaf packs if my lunch break is long enough...
Tue May 10, 2011 7:34 am
Tue May 10, 2011 7:35 am
Yes on the herculiner. It is a real pain to on the bottom of the floor pans. banghead
74, MONEY EATER
Tue May 10, 2011 11:02 am
32,973,181 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
