www.ColoradoClassicBroncos.com - View topic - Who is the resident Tranny guru?
It is currently Fri Oct 04, 2024 5:22 pm
Reply to topic  [ 9 posts ]
Post Who is the resident Tranny guru?
We are in need of repairs on my sons auto in his 66 mustang.
torque converter - spedo - seems that the flywheel has lost some teeth and while we have everything out we want to get it all done right.
I think it is a C4 but not positive. We will pull it and bring it to you.
also could use a engine hoist and enging stand while we have the trans out.
Probably need it for around 2 weeks depending on how long the repairs take for the trans
We may even want to upgrade from the 200 inline 6, it is tired but funds are limmited.
Fri May 13, 2011 8:02 am
Post Re: Who is the resident Tranny guru?
Pm viperwolf.
Fri May 13, 2011 10:58 am
x2, Viper is your guy. Also, I'd be a little more specific in the header about which sort of tranny guru you're seeking. You might wind up with a referral to a really tall, hairy chick with an Adam's apple.
Fri May 13, 2011 3:26 pm
Fri May 13, 2011 6:35 pm
Fri May 13, 2011 6:40 pm
lmao
Likely safe on this board but may not want to put that in a CraigsList search.
Fri May 13, 2011 6:47 pm
I have an engine hoist you could borrow
Fri May 13, 2011 10:06 pm
All the auto transmissions I've run over the last few years were built by Don Calander at the Transmission Clinic in COS. Everything from a C-4 with a full manual/reverse valve body to an AOD with 4R70W gear set, etc... I believe they have a shop in Castle Rock as well.
He's also a Bronco guy, although I don't know if he's on here or not.
HTH, Joe
Sat May 14, 2011 9:20 am
x3 for viper. he built my tranny and knows a TON!!
Thu May 19, 2011 9:02 am
32,458,655 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
