Got the passenger side door working again.... Purchased a new impact driver to loosen the screws and the top one still wont budge, actually bent the tip in the driver. But was able to get enough out of the lower to adjust it so the strike works well now.
Now all we need is the arm rests and the doors will be fully functional.... Hope the boys learned a lesson from this - leave the doors on, they are a PITA to get right once out of alignment.
Mon May 23, 2011 1:42 pm |
66and70Broncos
Joined: Tue May 10, 2011 9:58 pm Posts: 111 Images: 0 Location: Colorado Springs
removed top for the first time...Ah...I needed that. Got the passenger door working. Patched passenger floor and put the seat back in. Mounted fire ext. to rollbar. Just having fun with the top off.
_________________ Old EB 1966 I-6 170 New EB 1970 V-8 302 Next EB ? 5.0 EFI
Mon May 23, 2011 9:46 pm |
MOLLEY
Joined: Sat Dec 11, 2010 8:33 pm Posts: 54 Images: 1 Location: Parker, CO
removed both front axles and install new rcv joint axle assy .. they say they are tuffest axles on planet . hope so.
_________________ 66 Bronco (Molley) injected 418 stroker on juice, klune v ,4 speed atlas hi 9 35 spline air lockers front & rear, rcv axles. 37'' red krawlers. Four other sets of tires for ice racing and dirt drags. 290lbs of welding wire.
Mon May 23, 2011 11:47 pm |
Mon May 23, 2011 11:57 pm |
Tue May 24, 2011 7:32 am |
Tue May 24, 2011 8:22 am |
socofn
Finally figured out what my issue with only running a few minutes then dying. The fuel hose from the main tank was bent and kinked. I can say that I got real good at taking the carb off.
I did finish the seat install over the weekend and put on some cheap seat covers today. Me and my daughter took it on a short drive. I need to do some seat belts now.
Tue May 24, 2011 8:10 pm |
socofn
Might have been my son as he has been dying to drive it. I was ready to burn it to the ground as it was real pissing me off. Now I need to get a headliner made up and installed so I can drive it. I also need to get door parts as mine was missing both arm rests and interior handles. I did also order a petronix and get some new wires. JP
Tue May 24, 2011 8:50 pm |
I did a little work to mine. Installed a new CB as my old one was toast. Net up is to check and make sure everything is tight for a nice trouble free trip saturday.
Wed May 25, 2011 6:22 am |
socofn
Got the roll bar/light bar re-installed after painting, also I put the seatbelt in for the drivers side. My son asked me (after claiming he was to ill to help me) that he wanted to drive it to work, I told him he must have a fever. I do plan on driving it to work this weekend if the weather holds. JP
Wed May 25, 2011 2:20 pm |
Reamed out my new knuckles as part of my disc swap. Learned 2 things: Zoso's reamer doesn't fit in my 3/8ths drill and that it's pretty easy to do the reaming by hand. I'm really happy with the results and it only took about an hour to totally reinstall my tie rod and drag link.
Wed May 25, 2011 3:20 pm |
66and70Broncos
here's something new I tried today...I had a couple sets of OEM front seat belts that had apparently been laying around in a garage for some time...lots of dirt and grease. I took them to work with me and before I left sprayed one side at a time with engine decreaser...let it sit for a bit, then pressure washed. Flip repeat rinse...worked pretty good. As long as they dont wreak of engine degreaser they will be usable as they cleaned up amazingly well. If they stink I'll keep pressure washing until they dont.
Wed May 25, 2011 6:15 pm |
Did a little more today. Checked up my steering box and trac bar. All was still tight. Was a scary ride when they came loose on jenny creek last year. Also rewired in my pressure switch for my OBA. Now I just need to replace the hose off the compressor to the filter. Then I should be ready for this weekend.
Wed May 25, 2011 8:03 pm |
66and70Broncos
installed autofab hood pins...then went and bought some locks to go through the pins.
Im finding that there just arent enough hours in a day to get my Bronco projects done as quickly as I want to.
Wed May 25, 2011 11:12 pm |
Did an alignment. Hopefully my brake hoses will show up from BC Broncos tomorrow (ordered them last Friday morning ) and I can have my truck on the road for the run Saturday. It won't really be the same driving the minivan. Nothing like testing new mods with a 150+ mile drive.
Thu May 26, 2011 11:58 pm |
How about the best of them all. I bought a new to me 74. Now the long task of tearing it down.
Fri May 27, 2011 6:08 am |
Fri May 27, 2011 8:34 am |
Fri May 27, 2011 9:36 am |
Installed newly lengthened driveshaft and leaf spring shims to correct pinion angle! Bronco is ready to roll. Wish I was meeting you guys this weekend for the run!
Sat May 28, 2011 9:12 am |
Hey guess what i did. I drove the 79. first time in about 2 months maybe more. Gonna have to tear apart the rear end as I got some pretty good growling going on now.
Sat May 28, 2011 6:08 pm |
Growl or no growl it's a great truck. Thanks for letting me ride along today!
Sat May 28, 2011 11:23 pm |
socofn
Last night I got the lower door seals in temporarily so I could drive it today.
I did drive it to work today, and it was great, although a little chilly. JP
Sun May 29, 2011 2:17 pm |
Shawns Fords
Sun May 29, 2011 4:15 pm |
socofn
1998 honda accord from a local junk yard for $40 a set. I bought a set of cheap seat covers from advanced that fit great. JP
Sun May 29, 2011 9:07 pm |
MOLLEY
rcv axle update .. so far i notice that when turning tight there is no jumping / hopping , its smooth turning , the dust boots were a little tuff to push into place ,and also found that i need to grind down lower ball joint nut a little more on pass side .
Mon May 30, 2011 9:19 pm |
Got the disc conversion finished up. Still lots of small bubbles when I'm bleeding, but the rear tires lock long before I max out the pedal travel. Massively more powerful brakes. It'll need a proportioning valve and I'm curious to see how much more powerful the brakes get with a greater percentage of the work being done by the fronts. I'll probably replace all the brake parts from the master cylinder down to the front axle next to try to get rid of the bubbles and decrease the chance of failure by 40 year old parts.
Mon May 30, 2011 10:53 pm |
Tue May 31, 2011 6:20 am |
My bronco is ready for the next trip. Got my newly lengthened driveshaft installed and leaf spring wedges to correct pinion angle. Installed the shock again, although I think both are shot. They were both coated in dirt since I think they are leaking. That's the trouble with mounting them inboard, you place more of a side load on them as the suspension compresses and they are not designed for that.
Tue May 31, 2011 7:35 am |
socofn
Ordered new rancho (I would have loved to put on some bilsteins but coudn't justify the expense for a toy) shocks and steering stabilizer. Jp
Tue May 31, 2011 8:33 am |
airbur
Yesterday we removed the family cage...will be trailering it up to RoadRunner tomorrow for powdercoating. I also re-installed the entire interior (carpet, hold downs, seats, tunnel covers, seat belts etc.). Cage should drop right in on top of the carpet nicely.
Tue May 31, 2011 11:34 am |
