Register •
FAQ
• Login
It is currently Mon Oct 07, 2024 8:21 am
[ 6 posts ] |
socofn
2150 carb help
I need some help. My 74 started dying about 2 minutes after start up. It is getting fuel and seems like it is loading up and flooding. Not sure how to remedy this. I have disconected the electric choke power and this has not helped. Your expert assistance is needed. The bronco has a motorcraft 2150 which i rebuilt 2 months ago. Thanks JP
Sat May 21, 2011 10:10 pm |
Moab Mike
Re: 2150 carb help
Sun May 22, 2011 2:30 am |
Re: 2150 carb help
Disconnecting the power to the electric choke will only delay the choke from coming off. You might be seeing the choke set too tight. Try loosening the 3 screws holding the black choke housing and rotate the housing a little in the lean direction. The electric part aids in choke pull off by heating a bimetal spring. Could be that it doesn't have power to pull it off or the bimetal spring has fatigued and no longer working.
My dad removed the choke from the 2150 on my Bronco years before I owned it and never had an issue. Cold blooded and took some throttle feathering for a bit in the morning but always started.
Sun May 22, 2011 6:43 am |
socofn
Re: 2150 carb help
Thanks. I will give it a try when I get home. JP
Sun May 22, 2011 9:56 am |
Re: 2150 carb help
Try both of those. To rule out the choke right away is get some tie wire and wire it open. If its cold you'll have to feather the gas to get it to run for a bit. Good luck.
Sun May 22, 2011 11:08 am |
socofn
Re: 2150 carb help
Best i could figure it was a kinked fuel hose . I did replace a bunch of the rubber hose. I got real good at taking the carb off. I ordered a new electric choke from advanced and stuff to do a petronix and new wires. Thanks to all for the help. JP
Wed May 25, 2011 8:44 pm |
[ 6 posts ] |
