It is currently Sat Nov 23, 2024 2:40 pm
Reply to topic  [ 2657 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12, 13, 14 ... 89  Next
Took 3 good friends and went for a nice ride at sunset through Garden of the Gods. Man this new bronco runs GREAT!!! Picking up my 68 Charger on Saturday but it will have to sit for a while while I work on my EB :)
Old EB 1966 I-6 170
New EB 1970 V-8 302
Next EB ? 5.0 EFI
Thu Jun 02, 2011 9:42 pm
watered the 31's, they grew to 33's
If you look close you will note different tires but close enough for us front and rear.
I was driving down Broadway and noticed a pile of 33's that looked good at a tire store. Went in, negotiated a price ($250 for all 4 mounted and on the Bronco) said get-r-done!
4 good Micky Thompson's... sweet. Drove it 1 mile to the shop and the rt front was flat. Bad tire (split in the side wall) Went back and found 2 other good tires - now have the 33" spare too.
It'l do for now.
Fri Jun 03, 2011 2:25 pm
Fri Jun 03, 2011 3:34 pm
Pulled the top off yesterday and have been just driving it a little longer and further from the nest each day. Did about 35 miles total today and had it up to 60-65 for an extended period for the first time. Need to start poking around in the front end as it felt like it wanted to start getting wobbly at those speeds. Cruised well though, Sounded good and felt even better. I still have some work to do to increase the confidence factor but I'm making progress and learning a ton. I'm just enjoying driving it really.
Fri Jun 03, 2011 10:44 pm
Got it dirty. fire fire
Sat Jun 04, 2011 6:58 pm
Got my new shocks and steering stabilizer installed along with a new oil sending unit. Now I need to get my seat belts and I can start driving it more. Now I gotta find some 33's that aren't an arm and a leg. JP
74, MONEY EATER
Sat Jun 04, 2011 8:16 pm
Sat Jun 04, 2011 9:17 pm
took her out on I-25 for the first time and tested at higher speeds...3 spd Hurst leaves a little top end to be wanted but cruised pretty smooth at 60...better than my 66 EB with an I-6 though!
Old EB 1966 I-6 170
New EB 1970 V-8 302
Next EB ? 5.0 EFI
Sat Jun 04, 2011 11:17 pm
Pulled out the detrot locker... Inspected it... Put it back in... Yep still broken,but where?... Pulled it back out... Inspected it... Maybe I will weld it and put it back in, that'll fix it...
Sun Jun 05, 2011 6:42 pm
washed 5 lbs of mud off of it
WAHOO !
Sun Jun 05, 2011 6:48 pm
DROVE IT!!!! boardin
74, MONEY EATER
Sun Jun 05, 2011 7:15 pm
Mon Jun 06, 2011 8:09 am
Will put some gas in her and see what my fuel mileage was for the last 115miles +/-. Thank Zack for the phone app...I am excited to see how she does.
Mon Jun 06, 2011 8:11 am
Mon Jun 06, 2011 5:39 pm
I unpacked these babies..... YES!!!
Mon Jun 06, 2011 8:42 pm
Drove it most of the day today. Man it was HOT. I am going to have to remember to wear sunscreen. JP
74, MONEY EATER
Mon Jun 06, 2011 9:55 pm
Tue Jun 07, 2011 6:23 am
Images: 13
spent 490 bucks or so got all new brakes on my bronco, did that now on to my clutch, be done by friday, then engine seals should be in and by monday off to race and 100% mechanically sound. next 2 weeks new fuse boxs and dual batt set up
TRAVIS HOYLE
Tue Jun 07, 2011 8:48 pm
Profile YIM WWW
Images: 1
Opened the garage door and looked at it for awhile. Waiting for some parts.
Tue Jun 07, 2011 9:13 pm
Got 1 tire mounted up. Others by end of week then time to start cuttin...
Tue Jun 07, 2011 10:42 pm
Tue Jun 07, 2011 10:56 pm
Wed Jun 08, 2011 6:27 am
Wed Jun 08, 2011 7:06 am
Wed Jun 08, 2011 10:19 pm
Images: 13
kchaser
looks real nice what size tire and rims
TRAVIS HOYLE
Thu Jun 09, 2011 4:44 pm
Profile YIM WWW
Thu Jun 09, 2011 8:16 pm
I had a visitor today whom comes in from sterling to stay here for his treatments for health issues. He has an original halfcab and talked to me for hours about mine and what needs done. I can not wait to see his Bronco. Anyway to show off mine I fired it up and let it idle for a while. I was so happy to just let it idle and listen to it run without missing a beat. As soon as I get settled in here, I can get more work done.
Put new fuel lines on the Cuda as well and cleaned the racing wheels and aired up the slicks.
Thu Jun 09, 2011 9:43 pm
Zilla - that stinger looks nice smokin
Thu Jun 09, 2011 10:08 pm
Fri Jun 10, 2011 7:24 am
Brakes - new pads in front. Have to order new rotors - toast!
Need to check the rears - I am fairly certian I need to replace them as well.
And I think that it is the original fluid so a complete bleed is in order as well.
(Still tons of mud packed in and around the rotors from last weekends yankie hill run - imagine that! icon biggin )
Fri Jun 10, 2011 7:49 am
32,974,752 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
