It is currently Sat Nov 23, 2024 4:55 pm
Shawns Fords
That stinger does look good.
Fri Jun 10, 2011 10:05 am |
Crazyone
Joined: Tue Jan 25, 2011 9:33 am Posts: 207 Location: Aurora, CO
Installed my Explorer windshield washer / radiator overflow tank. Also added all new lines to and from the tank. It really cleaned up that area of my engine compartment and looks like it came from the factory that way.
Thanks to Viperwolf for the info on the tank. Great Mod!!!!
Tonight I'll be adding spring loaded needles & seats and whistle tubes to my Holley to help out in the hills.
_________________ You will not see me cry because I do not sing the blues
Fri Jun 10, 2011 11:33 am |
Zenzone
Fri Jun 10, 2011 11:40 am |
That Explorer tank looks new - did you Armor All it? Was it in a 2012 Explorer?
Fri Jun 10, 2011 12:10 pm |
Crazyone
Fri Jun 10, 2011 12:40 pm |
BNC04
I like that, I'm missing all the components for the wash and also the overflow so I think I'll be following that route as well. Anything to look for besides looking for a 90's explorer setup?
Brett
Fri Jun 10, 2011 3:28 pm |
Crazyone
Fri Jun 10, 2011 4:12 pm |
Fri Jun 10, 2011 5:44 pm |
I scored a hydroboost today. Hoping to start floor pan install this weekend.
Fri Jun 10, 2011 7:31 pm |
goldenboy_cp
Joined: Sat Mar 05, 2011 7:18 am Posts: 128 Images: 13 Location: Colorado springs, co
got brakes done
_________________ TRAVIS HOYLE
Fri Jun 10, 2011 8:29 pm |
Last edited by crawlercreations on Fri Jun 10, 2011 10:15 pm, edited 2 times in total.
Fri Jun 10, 2011 8:53 pm |
BFD305
Goldenboy - Were you driving the bronco? A six speed would be sweet. Not sure how the clutch was limitting 2 gears........Were you always running high RPM's cruising in 4th, or was there a huge gear drop from 2nd to 5th? Curious to see this one.
Fri Jun 10, 2011 9:41 pm |
airbur
Picked it up from the frame shop today. They measured up down and at every angle and can't find any issue with the frame. Not sure what the next step is.
Called Roadrunner Fab to get an ETA on my powdercoating but he couldn't give me a firm date. I was hoping to have it today for the weekend:(
Fri Jun 10, 2011 9:43 pm |
Part 213 of the hydroboost install. Getting close. I think I might have it out of the garage tomorrow.
Fri Jun 10, 2011 10:13 pm |
cobshane
Sat Jun 11, 2011 12:23 am |
goldenboy_cp
lol i wish i had answer, it is in my shop for moment( since i am haveing a garage sale and needed my garage, i drove my bronco a few days ago i get my bronco back monday, driving it high rpms well to tell you truth i am afraid of blowing my engine since it had ton leak before new clutch highest i got was 45 and it was reving idk maybe i didnt aliign it right and or somthing but idk or tranny guy and i are dumb......................:(
Sat Jun 11, 2011 8:49 pm |
Going with the :( on that one.
Sat Jun 11, 2011 8:57 pm |
cobshane
Sat Jun 11, 2011 9:24 pm |
cobshane
Finished up the steering today. Used the chevy 1 ton setup. It came out great!
Sat Jun 11, 2011 9:26 pm |
Sat Jun 11, 2011 9:28 pm |
66and70Broncos
Joined: Tue May 10, 2011 9:58 pm Posts: 111 Images: 0 Location: Colorado Springs
Thanks to Classic69Bronco who gave me a donor Wshield frame...Today was spent removing the old WS...straightening the new one and reworking some of the problem areas on the new WS. At the end of the day...I have a straight frame that's rewelded in the corners, smoothed, and painted on one side...
I have to say up front that the WS frame I had had the worst rot Ive ever seen at the bottom...and whoever decided that 38 spot welds was what it would take to keep the WS frame on needs smacked in the head...
and YES...I USED A FORKLIFT TO PULL MY WS FRAME STRAIGHT...whatever works!
_________________ Old EB 1966 I-6 170 New EB 1970 V-8 302 Next EB ? 5.0 EFI
Sun Jun 12, 2011 1:16 am |
Sun Jun 12, 2011 5:39 am |
(yesterday) got her all ready for today's wheelin trip
checked all the fluids and was surprised to find it 2 quarts low on oil so I spent time trying to track down the leak(s)
all I could find was the oil sender leaking (slightly) and even smaller leaks at the valve covers. I guess I will have to keep my eye on it more.
Sun Jun 12, 2011 5:43 am |
Zenzone
Spent last night mounting CB and fuel regulator and then neither one worked. Time to go tune them in before the wheeling trip.
Sun Jun 12, 2011 5:49 am |
kchaser
Joined: Sat May 07, 2011 5:54 pm Posts: 269 Location: Wellington
Finished mouting tires. Flares on order from WH so I can start trimming.
Sun Jun 12, 2011 9:34 am |
socofn
Drove it around the property and up a real steep incline. No issues. Gotta get my roll bar, soft top, rear seat and disk brakes now. I also need to get new tires and wheel flares. JP
Sun Jun 12, 2011 3:58 pm |
Went wheelin and learned some carb tuning stuff from Dan, Zen, and Dave.
oh yeah, I also heard a train coming through a tunnel on the way up to the wheelin spot
Sun Jun 12, 2011 8:44 pm |
Broke some more hydroboost stuff.
Sun Jun 12, 2011 9:05 pm |
cobshane
Took apart the front end again to raise the trackbar mount and put my new springs on. If If i can find a carrier quick, I'm going to throw in the 44 that's been sittin around in the garage. I'm puutin in a add in the parts wanted section. Needed for higher than the 3.73
Sun Jun 12, 2011 10:32 pm |
Mon Jun 13, 2011 6:45 am |
