Postby Shawns Fords » Fri Jun 10, 2011 9:05 am
That stinger does look good.
Shawns Fords
Postby Crazyone » Fri Jun 10, 2011 10:33 am
Installed my Explorer windshield washer / radiator overflow tank. Also added all new lines to and from the tank. It really cleaned up that area of my engine compartment and looks like it came from the factory that way.
Thanks to Viperwolf for the info on the tank. Great Mod!!!!
Tonight I'll be adding spring loaded needles & seats and whistle tubes to my Holley to help out in the hills.
Crazyone
Postby Zenzone » Fri Jun 10, 2011 10:40 am
Crazyone wrote:Installed my Explorer windshield washer / radiator overflow tank. Also added all new lines to and from the tank. It really cleaned up that area of my engine compartment and looks like it came from the factory that way.
Looks good. I plan to do a little tunning to my carb while we are up there this time, so we can tune yours in as well.
Zenzone
Postby Entourage » Fri Jun 10, 2011 11:10 am
That Explorer tank looks new - did you Armor All it? Was it in a 2012 Explorer?
Postby Crazyone » Fri Jun 10, 2011 11:40 am
Entourage wrote:That Explorer tank looks new - did you Armor All it? Was it in a 2012 Explorer?
Close, 1994 Explorer. Not new but you know me, I got make things look nice so I cleaned it up a bit.
Crazyone
Postby BNC04 » Fri Jun 10, 2011 2:28 pm
I like that, I'm missing all the components for the wash and also the overflow so I think I'll be following that route as well. Anything to look for besides looking for a 90's explorer setup?
Brett
BNC04
Postby Crazyone » Fri Jun 10, 2011 3:12 pm
BNC04 wrote:I like that, I'm missing all the components for the wash and also the overflow so I think I'll be following that route as well. Anything to look for besides looking for a 90's explorer setup?
Brett
Nothing that I know of to look for really. I know some of the guys have found them in pick and pulls for less than $10. I don't have alot of time to go to salvage yards so I found mine on Ebay. Got it for $25 shipped to my door. Just make sure the pump motor works as those are like $35 new. The other nice thing about it is the Bronco connector hooks right up to it. No mods needed there and I only drilled 1 new hole to mount it. I used the OE top inner fender bolt to mount the forward tab to. Real easy to do. Took me about 45 minutes to do the complete job. Good luck, you'll like it.
Crazyone
Postby Justin » Fri Jun 10, 2011 4:44 pm
Brett
You'll find one in less that 10 minutes at any junkyard and it'll take you another 10 to get it out. There were a couple in the yard in Dacono when I was there last, but that place isn't cheap.
Postby ZOSO » Fri Jun 10, 2011 6:31 pm
I scored a hydroboost today. Hoping to start floor pan install this weekend.
Postby goldenboy_cp » Fri Jun 10, 2011 7:29 pm
got brakes done
TRAVIS HOYLE
goldenboy_cp
Images: 13
Postby crawlercreations » Fri Jun 10, 2011 7:53 pm
goldenboy_cp wrote:100% all new brakes im still running drum's all new pads lines whole thing, than ks to 2 yr worth of gift cards to auto zone, well got into clutch, HERE FUNNY THING, I THOUGHT I HAD A 4 SPEED H PATTERN, WELL I FOUND OUT MY CLUTCH WAS SOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO BAD I ACTUALLY HAVE A 6 SPEED AND I NEVER KNEW IT, WENT AND CALLED TRANMISSION SHOP, (INCASE I AM CRAZY) AND YEA ITS A 6 SPEED
So somebody went through all the trouble and custom work to install a 6 speed but they never upgraded the brakes from drums?? What 6 speed is it? If the transmission shop KNOWS it is a 6 speed they should be able to tell you exactly which one it is? May be one of the first 6 speeds in a bronco I have heard of. shrug What t- case is behind it? Who makes the custom bell housing? We need some pictures of this beast of a transmission crammed into a bronco! laughing2
Last edited by crawlercreations on Fri Jun 10, 2011 9:15 pm, edited 2 times in total.
Postby BFD305 » Fri Jun 10, 2011 8:41 pm
Goldenboy - Were you driving the bronco? A six speed would be sweet. Not sure how the clutch was limitting 2 gears........Were you always running high RPM's cruising in 4th, or was there a huge gear drop from 2nd to 5th? Curious to see this one.
BFD305
Images: 5
Postby airbur » Fri Jun 10, 2011 8:43 pm
Picked it up from the frame shop today. They measured up down and at every angle and can't find any issue with the frame. Not sure what the next step is.
Called Roadrunner Fab to get an ETA on my powdercoating but he couldn't give me a firm date. I was hoping to have it today for the weekend:(
airbur
Postby akaFrankCastle » Fri Jun 10, 2011 9:13 pm
Part 213 of the hydroboost install. Getting close. I think I might have it out of the garage tomorrow.
Postby cobshane » Fri Jun 10, 2011 11:23 pm
Let's see pics, I am jealous. I thought the nv 4500 was sweet. So it's a nv5600 or the
zfs 650? Oh there's the newer jeep six speed nsg 370.
That is a weird clutch problem.
cobshane
Images: 1
Postby goldenboy_cp » Sat Jun 11, 2011 7:49 pm
lol i wish i had answer, it is in my shop for moment( since i am haveing a garage sale and needed my garage, i drove my bronco a few days ago i get my bronco back monday, driving it high rpms well to tell you truth i am afraid of blowing my engine since it had ton leak before new clutch highest i got was 45 and it was reving idk maybe i didnt aliign it right and or somthing but idk or tranny guy and i are dumb......................:(
TRAVIS HOYLE
goldenboy_cp
Images: 13
Postby crawlercreations » Sat Jun 11, 2011 7:57 pm
Going with the :( on that one.
Postby cobshane » Sat Jun 11, 2011 8:24 pm
zillacon wrote:
crawlercreations wrote:Going with the :( on that one.
Just wait until I post up my 6 Speed doubler! 12 Speeds Biotch! flipoff laughing2
NICE!!!!!
cobshane
Images: 1
Postby cobshane » Sat Jun 11, 2011 8:26 pm
Finished up the steering today. Used the chevy 1 ton setup. It came out great!
cobshane
Images: 1
Postby ZOSO » Sat Jun 11, 2011 8:28 pm
Me too, thats about all I can understand.
Postby 66and70Broncos » Sun Jun 12, 2011 12:16 am
Thanks to Classic69Bronco who gave me a donor Wshield frame...Today was spent removing the old WS...straightening the new one and reworking some of the problem areas on the new WS. At the end of the day...I have a straight frame that's rewelded in the corners, smoothed, and painted on one side...
I have to say up front that the WS frame I had had the worst rot Ive ever seen at the bottom...and whoever decided that 38 spot welds was what it would take to keep the WS frame on needs smacked in the head...
and YES...I USED A FORKLIFT TO PULL MY WS FRAME STRAIGHT...whatever works!
Old EB 1966 I-6 170
New EB 1970 V-8 302
Next EB ? 5.0 EFI
66and70Broncos
Postby Rox Crusher » Sun Jun 12, 2011 4:39 am
66and70Broncos wrote:and YES...I USED A FORKLIFT TO PULL MY WS FRAME STRAIGHT...whatever works!
seems natural enough to me
burnout
Postby Rox Crusher » Sun Jun 12, 2011 4:43 am
(yesterday) got her all ready for today's wheelin trip
checked all the fluids and was surprised to find it 2 quarts low on oil so I spent time trying to track down the leak(s)
all I could find was the oil sender leaking (slightly) and even smaller leaks at the valve covers. I guess I will have to keep my eye on it more.
Postby Zenzone » Sun Jun 12, 2011 4:49 am
Spent last night mounting CB and fuel regulator and then neither one worked. Time to go tune them in before the wheeling trip.
Zenzone
Postby kchaser » Sun Jun 12, 2011 8:34 am
Finished mouting tires. Flares on order from WH so I can start trimming.
kchaser
Postby socofn » Sun Jun 12, 2011 2:58 pm
Drove it around the property and up a real steep incline. No issues. Gotta get my roll bar, soft top, rear seat and disk brakes now. I also need to get new tires and wheel flares. JP
74, MONEY EATER
socofn
Postby Rox Crusher » Sun Jun 12, 2011 7:44 pm
Went wheelin and learned some carb tuning stuff from Dan, Zen, and Dave.
oh yeah, I also heard a train coming through a tunnel on the way up to the wheelin spot
Postby akaFrankCastle » Sun Jun 12, 2011 8:05 pm
Broke some more hydroboost stuff. banghead
Postby cobshane » Sun Jun 12, 2011 9:32 pm
Took apart the front end again to raise the trackbar mount and put my new springs on. If If i can find a carrier quick, I'm going to throw in the 44 that's been sittin around in the garage. I'm puutin in a add in the parts wanted section. Needed for higher than the 3.73
cobshane
Images: 1
Postby Rox Crusher » Mon Jun 13, 2011 5:45 am
Classic69Bronco wrote:Took the Bronco out on Saturday, put about 30miles on it. Suspension is crazy loose. Got my first taste of death wobble, I am pretty sure that the car behind thought I was drunk.
Yesterday, I started on my 3spd floor shifter and t-case lever conversion. I have to adjust my 2 to 3 linkage, grinding a bit going in 2nd. I still need to attach the t-case linkage.
It was a good weekend.
You know your an EB addict when you experience the death wobble and still classify the weekend as good.
icon biggin
Return to Chit Chat
