Power Steering steering shaft?
Postby totalchaos » Fri Apr 01, 2011 3:48 pm
Looking for a steering shaft out of a bronco that had power steering Im converting my 66 bronco from manual to a stock power steering set up and my steering shaft is totally different
Im your huckleberry
totalchaos
Re: Power Steering steering shaft?
Postby cobshane » Sat Apr 02, 2011 12:43 pm
You can use a 3/4 round to a 36 spline ujoint just cut the shaft and weld the smooth part in. I got one at ontrack off santefe road.
cobshane
Images: 1
Postby cobshane » Sat Apr 02, 2011 12:44 pm
coberlyshane wrote:You can use a 3/4 round to a 36 spline ujoint just cut the shaft and weld the smooth part in. I got one at ontrack off santefe road.
Can't remember for if it was 36 spline. You might want to count.
cobshane
Images: 1
Postby totalchaos » Sat Apr 02, 2011 1:21 pm
Ok Ill check it out and get back with you thanks
Im your huckleberry
totalchaos
Postby Woodscaper » Sun Apr 03, 2011 1:08 pm
I think it is 13/16" x 36 spline on that box.
Woodscaper
Postby cobshane » Sun Apr 03, 2011 3:16 pm
jtsbronc wrote:I think it is 13/16" x 36 spline on that box.
Ya your right it is 13/16. That's what you need. Alot easier than swapping out a column.
cobshane
Images: 1
Postby totalchaos » Tue Apr 05, 2011 8:36 am
You know where I might find one?
Im your huckleberry
totalchaos
Postby cobshane » Tue Apr 05, 2011 3:08 pm
Ontrack performance off santefe road. Or summit racing. West coast broncos. To name a few.
cobshane
Images: 1
Postby totalchaos » Thu Jun 09, 2011 2:10 am
I about have all my steering parts and i think i found that knuckle on ebay but it say 13/16 3/4 by 36 tooth would that be the right one??
Im your huckleberry
totalchaos
Postby cobshane » Fri Jun 10, 2011 10:38 pm
totalchaos wrote:I about have all my steering parts and i think i found that knuckle on ebay but it say 13/16 3/4 by 36 tooth would that be the right one??
That's the one! The 13/16 is the box side with splines, and the 3/4 is the smooth side for were you cut the steering shaft.
cobshane
Images: 1
Postby totalchaos » Sat Jun 11, 2011 10:28 pm
Awesome I just wanted to make sure before I ordered thanks for the help!
Im your huckleberry
totalchaos
Return to Bronco Parts Wanted
