GMAN wrote:Saturday, I finished my hydroboost WOW what a difference ... Now I can SEE and STOP
WestMuddy wrote:I am intrested in your hydroboost. I am halfway through a disc conversion and am still trying to figure out how I am going to add a boost. I plan to hook up the proportioning/residual pressure valve from an '84 Jeep Wagoneer to the original master cylinder. At the moment I have no idea how well that will work.
Classic69Bronco wrote:Took the Bronco out on Saturday, put about 30miles on it. Suspension is crazy loose. Got my first taste of death wobble, I am pretty sure that the car behind thought I was drunk.
Yesterday, I started on my 3spd floor shifter and t-case lever conversion. I have to adjust my 2 to 3 linkage, grinding a bit going in 2nd. I still need to attach the t-case linkage.
It was a good weekend.
66and70Broncos wrote:Thanks to Classic69Bronco who gave me a donor Wshield frame...Today was spent removing the old WS...straightening the new one and reworking some of the problem areas on the new WS. At the end of the day...I have a straight frame that's rewelded in the corners, smoothed, and painted on one side...
I have to say up front that the WS frame I had had the worst rot Ive ever seen at the bottom...and whoever decided that 38 spot welds was what it would take to keep the WS frame on needs smacked in the head...
and YES...I USED A FORKLIFT TO PULL MY WS FRAME STRAIGHT...whatever works!
zillacon wrote:Ordered a rebuild kit for my Tranny along with new motor and Tranfer mounts. Toms macthed Advanced prices with no questions asked.
ZOSO wrote:zillacon wrote:Ordered a rebuild kit for my Tranny along with new motor and Tranfer mounts. Toms macthed Advanced prices with no questions asked.
What tranny are you going with?
Entourage wrote:ZOSO wrote:zillacon wrote:Ordered a rebuild kit for my Tranny along with new motor and Tranfer mounts. Toms macthed Advanced prices with no questions asked.
Dan is going with the one that had a Camper for sale a while back.
zillacon wrote:Removed the Explorer harness off my motor, cleaned things up read up on EFI conversions until my eyes bugged out and touched the computer screen.
Also ordered my RJM harness today, LUK clutch, pilot bushing, throw out bearing, clutch equalizer bracket, EFI Tank, pump, sending unit, o2 Bungs, throttle cable and fuel lines. I am still cooling off my Debit card under a bag of ice and really shoulda
. The wife is gonna
66and70Broncos wrote:Just drove it to and from work...but I have big plans for next week.
How many of you use your Bronco as a daily driver?
Justin wrote:Got some safety upgrades done. Installed my shiny new 3 point belts to get rid of the dangerously mounted 4 point harnesses. Went through and replaced most of the mounting hardware on my roll bar. Turns out the previous owner didn't believe in putting washers between the body and the nuts, added some great big ones to reinforce the body a little.
coberlyshane wrote:Justin wrote:Got some safety upgrades done. Installed my shiny new 3 point belts to get rid of the dangerously mounted 4 point harnesses. Went through and replaced most of the mounting hardware on my roll bar. Turns out the previous owner didn't believe in putting washers between the body and the nuts, added some great big ones to reinforce the body a little.
Why were they mounted so dangerously. Were they welded into sheet metal. I have seen it before
