Internal door parts
Internal door parts
Postby Justin » Fri Jun 17, 2011 5:20 pm
I need:
A driver's side rear window track
One of the little plastic wheels that goes into the track on the bottom of the window to help it go up and down
One of the knobs that screws onto the rod that locks/unlocks the door (the part your fingers touch to make this happen). I could probably get one at a parts store, but then it would be prettier than anything else on my truck.
Re: Internal door parts
Postby hockeydad4-22 » Fri Jun 17, 2011 7:10 pm
Justin - I have your wheel - no problem there.
Had to buy them for both boys cars - so I bought 8 knowing they would lose several.
I will go dig one out now and bring it to the breakfast. See you there.
and like your break line - you can not complain about the price... icon biggin
Postby Justin » Fri Jun 17, 2011 7:42 pm
Any chance you can spare a second? I'm guessing the drivers side one is fairly worn as well. Thank you!
Postby hockeydad4-22 » Sat Jun 18, 2011 12:30 pm
Justin,
Sorry I did not see this post last night. I will have to go and dig through the parts bins. Rox needs one too.
If I can find them they are yours (both of you guys)... You know how it is wiht small parts and teenage son's workign on them... things do not always get put away the way you would do it yourself)
Postby Justin » Sat Jun 18, 2011 2:37 pm
Hey, no sweat, I really appreciated the one you had with you. I can order some, this will allow me to at least get the one busted window fixed.
Return to Bronco Parts Wanted
