JGZ wrote:There are two different sets of linkage.One for T-shift T-case and one for J-shift T-case.Hope that helps. JGZ
zillacon wrote:My RJM EFI Harness showed up today as well as my Luk Clutch. I also finished up y spare trans and painted it up.
Rox Crusher wrote:zillacon wrote:My RJM EFI Harness showed up today as well as my Luk Clutch. I also finished up y spare trans and painted it up.
what do you think of the harness now that you have it in hand ?
hockeydad4-22 wrote:zillacon wrote:My RJM EFI Harness showed up today as well as my Luk Clutch. I also finished up y spare trans and painted it up.
"finished up my spare trans and painted it up"
Seriously Dan - half of us are doing well to have a spare tire. I like to go prepared and all but that is incredible... I mean who has a "spare trans"?
Booger wrote:I barely got the Bronco home tonight. About 3 blocks away it popped and wheezed and then would barely run. I had to pump it to keep it kinda running. Got to the top of our street and it quit. Coasted it down the street and into the driveway and that was it. Popped the hood a bit ago and took off the air cleaner and no squirt into the carb. Turned it over several times to no avail. Either pump is fubar, filter is clogged, or clogged fuel line. It's been running flawless and I was trying to think of anything I might need to do to it before Ouray, now I know what I get to look at this weekend, besides the drive shafts getting dropped and greased and all lube checked.
Wish I had a blanket that could catch the ATF that leaks so I wouldn't have to keep topping it off. Oh well keeps it fresher that way.
ZOSO wrote:You do know that it will stop leaking eventually and will still drive.
Entourage wrote:Added new Hi-Lift to rear tire carrier and hooked up the license plate lights . . .
akaFrankCastle wrote:I consider every day I drive the Bronco to be a trip to a Bronco event. Never know when I am going to run in to another Bronco...or three.
66and70Broncos wrote:Thanks...I'm actually a bit closer to the one on Cimmaron/21st...but worth the extra mile if it helps me out in a pinch...you working on your Bronco today?
socofn wrote:Drove it to town today and filled it up with liquid cash. I gotta figure out the gas gauge issue, it reads full for ever then drops to 1/2 quickly. Have a super fourth everyone. JP
Rox Crusher wrote:got my ars kicked by a water pump
