It is currently Sat Nov 23, 2024 4:19 pm
Reply to topic  [ 2657 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15, 16, 17 ... 89  Next
There are two different sets of linkage.One for T-shift T-case and one for J-shift T-case.Hope that helps. JGZ
Sun Jun 26, 2011 7:16 pm
Since my 73 is not done i took my 93 out on Saturday. It broke (rear chromo axle) worked on getting that apart all day. Man i hate C clip 8.8s and E-lockers
Sun Jun 26, 2011 8:55 pm
Sun Jun 26, 2011 10:26 pm
Took her for a spin now that she has plates and is all legal burnout
Heard some interesting metal on metal rubbing noises while coasting, need to check the brakes. Also spitting coolant out of the radiator so I'm wondering if it needs a new t-stat.
I may just need to trade a couple of you guys a whole lotta beer to come look it over with me and help me figure out what all I need to do to get it happy and on the road again. laughing2
Mon Jun 27, 2011 8:35 pm
Dan...who can compete with you....!!!! I saw that on the cart this weekend!
Drove Lucy to work today....and was giddy the whole way.....and back!
Thanks to all!
Matt
Mon Jun 27, 2011 8:45 pm
started tearing into my 5.0
Mon Jun 27, 2011 10:14 pm
Mon Jun 27, 2011 10:15 pm
Tue Jun 28, 2011 6:54 am
Well I like the way you think. And having watched the boys launching Free Bird into that deep mud hole... I think i have a pretty good idea who the prime candidate is for it... You might need two.
Tue Jun 28, 2011 7:07 am
Last week the engine went from this
to this
to this-
Heads are off getting new springs installed for the new cam.
Going with a new Manifold, cam, timing gear, distributor, and water pump.
Brett
Tue Jun 28, 2011 8:20 am
Tue Jun 28, 2011 8:35 am
Tue Jun 28, 2011 11:44 am
I went to Western Truck and Trailer and got me a new air horn. $20! I Called Holley and got some answers as to why my 470 truck avenger Carb was not working well. They are sending me a new 670 for free, should be here by the weekend. I also took some pictures of the stock pile or york compressors they have, most of the time they just throw them away at Western Truck and Trailer. If you need one go there and get it and an aluminum air tank and all the fittings you could ever need for dirt cheap.
Taking my air horn off truck
Yorks all over
Tue Jun 28, 2011 4:58 pm
Got my floor shifter in and working. Then took the proportioning valve out to get the bad line off. Put a new line on and back in then bled and have a good pedal. but there is something wrong with the fronts. This is irrelevant as all of the drum front gets swapped to the 8 lug once I have new calipers and wheel bearings and seals.
I have my rear perches to finish welding down also. then I can work on mounting the shocks.
Tue Jun 28, 2011 5:50 pm
I barely got the Bronco home tonight. About 3 blocks away it popped and wheezed and then would barely run. I had to pump it to keep it kinda running. Got to the top of our street and it quit. Coasted it down the street and into the driveway and that was it. Popped the hood a bit ago and took off the air cleaner and no squirt into the carb. Turned it over several times to no avail. Either pump is fubar, filter is clogged, or clogged fuel line. It's been running flawless and I was trying to think of anything I might need to do to it before Ouray, now I know what I get to look at this weekend, besides the drive shafts getting dropped and greased and all lube checked.
Wish I had a blanket that could catch the ATF that leaks so I wouldn't have to keep topping it off. Oh well keeps it fresher that way.
Tue Jun 28, 2011 7:03 pm
Tue Jun 28, 2011 7:14 pm
Tue Jun 28, 2011 7:31 pm
Added new Hi-Lift to rear tire carrier and hooked up the license plate lights . . .
Wed Jun 29, 2011 12:16 am
Wed Jun 29, 2011 12:20 am
Hell to the Yeah - they are never coming off! I am always going to be traveling to a Car Show, Parade, or Club Event smokin
Wed Jun 29, 2011 12:21 am
I consider every day I drive the Bronco to be a trip to a Bronco event. Never know when I am going to run in to another Bronco...or three.
Wed Jun 29, 2011 12:34 am
Wed Jun 29, 2011 7:17 am
got my ars kicked by a water pump
Sun Jul 03, 2011 4:51 pm
Installed front seat belts...way overdue. Then rewired alternator to see if that would fix the charging issue. Went to Advance to get everything tested...they closed 5 minutes before I got there. Stoplight screwed me...could see customers coming and going in and out then doors locked when I pulled in...to top it off...got rained on driving home. Had the top off and no rain in the forecast at all. But all is good...just light rain...got it parked and covered before the heavy rain came!
Just nice to actually have some time to mess with the old gal.
Old EB 1966 I-6 170
New EB 1970 V-8 302
Next EB ? 5.0 EFI
Sun Jul 03, 2011 6:58 pm
If you run in to another issue with "close to closing time" at Advance and are headed to the store on Nevada and Fillmore, call ahead and talk to Vaughn. Good kid and likes Broncos. Just tell him you "work with Zack and Colorado Classic Broncos". I probably just missed you if you were headed to that store. Was down there swapping out a belt for the Bronco.
Mon Jul 04, 2011 6:06 am
Thanks...I'm actually a bit closer to the one on Cimmaron/21st...but worth the extra mile if it helps me out in a pinch...you working on your Bronco today?
Old EB 1966 I-6 170
New EB 1970 V-8 302
Next EB ? 5.0 EFI
Mon Jul 04, 2011 10:02 am
Drove it to town today and filled it up with liquid cash. I gotta figure out the gas gauge issue, it reads full for ever then drops to 1/2 quickly. Have a super fourth everyone. JP
74, MONEY EATER
Mon Jul 04, 2011 12:43 pm
Mon Jul 04, 2011 1:26 pm
Sounds correct Frank, I replaced the sending unit and probably did not get the float in correctly. Once I start driving it more frequently I will keep up with the mileage. I have already run out of gas and my son nor wife still haven't let me live that down. JP
74, MONEY EATER
Mon Jul 04, 2011 1:43 pm
Mon Jul 04, 2011 3:22 pm
Users browsing this forum: No registered users and 23 guests
32,976,512 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
