www.ColoradoClassicBroncos.com - View topic - Backfiring thru TB
It is currently Sat Nov 23, 2024 2:58 am
Reply to topic  [ 22 posts ]
 Backfiring thru TB
Post Backfiring thru TB
Just finished my efi swap and trying to tune it a little and it is back firing through the TB. Could that just be a timing issue or the valves not adjusted right.
i did put new heads on and new cam, lower end is still stock 302 from 71 with about 79,000 miles on it. What do you guys think?
Thu Jun 30, 2011 10:54 am
Post Re: Backfiring thru TB
Could be a lot of things. Is it a regular backfire or does it only happen when you open the throttle?
Check the timing with a light and SPOUT unplugged. 10 BTDC is fine.
Check fuel pressure. About 39 psi is correct.
Check for codes.
Thu Jun 30, 2011 11:21 am
...check your upper intake!
Do you by chance have a typhoon intake???? ..ask me how I know to check that intake.
Thu Jun 30, 2011 7:40 pm
I DON'T THINK I HAVE A TYPHOON INTAKE. JUST STOCK AS FAR AS I AM AWARE OF. WHAT IS THE DIFFERENCE.
Fri Jul 01, 2011 1:38 pm
fuel pressure sitting at ~40 psi. Timing set @ 10 degrees btdc. Still backfiring and won't idle. PLEASE HELP. Or maybe someone will come on over for a little brew and some troubleshooting.
Sat Jul 02, 2011 12:39 pm
What parts went into the EFI mix? Part numbers from MAF, ECM, etc.
Sat Jul 02, 2011 3:45 pm
Sun Jul 03, 2011 12:05 am
Everything came of a 91 gt mustang. A9L computer, stock tb (looks 55mm to me). I will try to get some of the other part #'s later. If I do not have vacuum hoses right would that cause this?
Sun Jul 03, 2011 8:45 am
Sun Jul 03, 2011 8:47 am
anybody know the correct vacuum hose diagram. tried to find one online but nothing really helps because of whole mustang intake / bronco retro fit.
Mon Jul 04, 2011 6:28 am
There are only a few vac hoses needed. Fuel pressure regulator and PCV valve both get connected to the upper intake. Also a vent line from crankcase/valve cover needs to connect to filtered and metered air. All other vac ports should be blocked.
Mon Jul 04, 2011 7:36 am
If you a older cam 15426378 ignition order you need to change the injector harness ingnition order to spray fuel at the right time. Just reminder double check spark plug wire order.
66 half cab 4bt with AOD 16" coil overs 3link front 4 link rear 37s w/beadlocks
Mon Jul 04, 2011 4:26 pm
Profile WWW
Mon Jul 04, 2011 5:05 pm
The mustangs are sequential fuel injection. This means the injector fires fuel with ignition timing.If it is the older firing order the injectors are not firing at the same time as the valve opening and spark timing. If injectors are firing at the wrong time fuel is being put into cylinder at the wrong time and will make it run poor. I change the order at the 10 pin plugs that are black and white.
Mon Jul 04, 2011 5:21 pm
Profile WWW
Mon Jul 04, 2011 5:25 pm
OK just trying to help. Thx
Mon Jul 04, 2011 5:31 pm
Profile WWW
Thanks Viper. Need to reconfigure the vacuum lines and should be good. Cross my fingers. I want to drive it again.
Tue Jul 05, 2011 6:15 am
Thanks GSMITH. I do have a new cam with the ho firing order. Welcome to the board.
Tue Jul 05, 2011 6:21 am
Great thread.....will be doing something similar one of these days.
GSMITH.....in case you were wondering...Viper is the be-all-end-all EFI master (among most everything else Bronco:).....
http://classicbroncos.com/forums/showth ... write+book
Tue Jul 05, 2011 8:18 am
Bob, shoot me a PM if you'd like me to take a look at it. I think we're in the same area of town.
Tue Jul 05, 2011 2:54 pm
Wed Jul 06, 2011 6:28 am
Still popping through tb. All vacuum lines hooked up correctly. Timing is set to 10 btdc with spout out. Anything else?
Wed Jul 06, 2011 2:39 pm
32,965,195 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
