Register •
FAQ
• Login
It is currently Wed Jun 26, 2024 6:57 am
[ 7 posts ] |
9" pinion yoke pre load setting?
Woodscaper
Joined: Fri Nov 19, 2010 11:16 pm Posts: 587 Location: Lakewood/Green Mtn.
I need to swap the pinion yoke on the rear diff. The more I look into it the more questions I have. How do you determine the preload on the old yoke and make sure the new one is set properly? is it a matter of torqe or pinion drag or what ? Do I need to pull the center section to do it or just pull the nut and put the new one on ? Any tips would be helpfull. Thanks.
Thu Jul 07, 2011 4:49 pm |
Woodscaper
Re: 9" pinion yoke pre load setting?
Thats more like it, nice and easy. Thanks
Thu Jul 07, 2011 5:08 pm |
cobshane
I go just a hair passed your mark just to make sure there is still tension in the crush sleeve.
Thu Jul 07, 2011 6:31 pm |
Or replace the crush sleeve.
Fri Jul 08, 2011 8:56 am |
Fri Jul 08, 2011 11:12 am |
Woodscaper
Ok so, I either went half a turn to far or half a turn to short? It seems to be real tight (the nut) I put my torqe wrench on it just to see about how tight it was and its about 120 ftlb now, is there a typical torqe rang? Should I leave it or go the half turn more ?
Sat Jul 09, 2011 2:01 pm |
150-175 is pretty good. As long as your rotational torque is within spec.
Sat Jul 09, 2011 5:04 pm |
[ 7 posts ] |
