www.ColoradoClassicBroncos.com - View topic - 9" pinion yoke pre load setting?
It is currently Thu Nov 21, 2024 7:45 pm
Reply to topic  [ 7 posts ]
Post 9" pinion yoke pre load setting?
I need to swap the pinion yoke on the rear diff. The more I look into it the more questions I have. How do you determine the preload on the old yoke and make sure the new one is set properly? is it a matter of torqe or pinion drag or what ? Do I need to pull the center section to do it or just pull the nut and put the new one on ?
Any tips would be helpfull.
Thanks.
Thu Jul 07, 2011 4:49 pm
Post Re: 9" pinion yoke pre load setting?
Thats more like it, nice and easy. Thanks
Thu Jul 07, 2011 5:08 pm
Images: 1
I go just a hair passed your mark just to make sure there is still tension in the crush sleeve.
Thu Jul 07, 2011 6:31 pm
Or replace the crush sleeve.
Fri Jul 08, 2011 8:56 am
Fri Jul 08, 2011 11:12 am
Ok so, I either went half a turn to far or half a turn to short? It seems to be real tight (the nut) I put my torqe wrench on it just to see about how tight it was and its about 120 ftlb now, is there a typical torqe rang? Should I leave it or go the half turn more ?
Sat Jul 09, 2011 2:01 pm
150-175 is pretty good. As long as your rotational torque is within spec.
Sat Jul 09, 2011 5:04 pm
32,928,692 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
