It is currently Sat Nov 23, 2024 6:36 pm
Got the new column in. It's a tad too short, but it'll work fine. Tomorrow, the lower steering shaft and steering wheel go back on.
Wed Jul 13, 2011 11:35 pm |
socofn
Headed out to start the front disc brakes after picking up the spindles and hubs from Shane. Wish me luck. Jayson
Thu Jul 14, 2011 12:27 pm |
installed some new to me armrests (THANK YOU 76ford)
installed some nifty wing window locks (THANKS AGAIN 76ford)
continuing to clean the 5.0 up for paint, etc
wondering what to do with the intakes.................maybe blast and clear coat ?............maybe polish...............maybe just clean up real good
any ideas / suggestions ?
Thu Jul 14, 2011 6:43 pm |
Installed a free window sticker from Wild Horses. They also sent me a cool t-shirt. Surprising what you can get thrown in when you cry uncontrollably on the phone about the cost of new 31 Spline HD axles No surprise, the axles, bearings, bushings, and retainers that Jim recommended fit perfectly.
Tue Jul 19, 2011 1:04 pm |
airbur
Wow...what else did you get for free? You are a rolling billboard sign for them now!
Tue Jul 19, 2011 1:06 pm |
Unspooled my winch and put a new end on the line so I can respool it and hope it holds the weight. I need to source some sticky back rubber strap to spool on the drum first to help the cable bite.
Tue Jul 19, 2011 1:15 pm |
75DBE
So from a MUCH earlier post -- "Today she gets all of the unnecessary mechanical equipment taken off from under the hood." I assume that means the smog / emissions control piping and the air pump, etc.?
Tue Jul 19, 2011 1:42 pm |
Moab Mike
Tue Jul 19, 2011 6:09 pm |
Moab Mike
I saw swiegum turning onto C470 from Bowles at 4:22 PM. SURE LOOKS SHARP!!!!!
Tue Jul 19, 2011 6:24 pm |
66and70Broncos
Joined: Tue May 10, 2011 9:58 pm Posts: 111 Images: 0 Location: Colorado Springs
Drove to work and someone had a truck and 35 foot trailer in front of where I park...no problem...over the curb I went to get around it. Stopped by Advance as my blinker switch had gotten water in it...replaced it for free...now Ive weatherproofed the switch to avoid the same thing happening.
_________________ Old EB 1966 I-6 170 New EB 1970 V-8 302 Next EB ? 5.0 EFI
Tue Jul 19, 2011 6:30 pm |
Badlands
Tue Jul 19, 2011 8:54 pm |
Drove it to and from work yesterday and today - and taking it camping and wheeling this weekend!
So there!
Fri Jul 22, 2011 8:26 am |
Had to break the news to mine that she wasn't going camping with us this weekend... :(
But I plugged her into the battery tender to keep her young and fresh!
Fri Jul 22, 2011 8:27 am |
WestMuddy
Performed last night:
Connected header pipes and new mufflers up; Finished cover over NP435 tranny (tranny still on shop floor 'cause of the lack of tranny-to-xfer adapter); Filled new (to this buggy) Dana 44 axle, tired 3 speed tranny, xfer case, old 9" ford rear axle; Put cotter pins in new tie rod assembly; Reconnected engine (carberator, heater, etc); Reinstalled, cleaned up and filled battery; Inspected new (to this buggy) front disk brakes;
Tried to start it and ended by scratching my head over why it wasn't pulling fuel out of the tank.
Mon Jul 25, 2011 10:08 am |
75DBE
Took out the frozen 302 and started prepping the Donor 302 for install! Craziness.
Mon Jul 25, 2011 10:42 am |
Didn't really do anything to MY Bronco today, but... I did buy a tub.
Tue Jul 26, 2011 7:33 pm |
I knew that wouldnt last long. You just couldnt wait to get it all perfect huh?
Tue Jul 26, 2011 7:54 pm |
Wed Jul 27, 2011 7:31 am |
Wed Jul 27, 2011 10:51 am |
75DBE
Certainly what I need to look at next -- after the engine. My doors sag a bit (passenger worse than driver) and are hard to close and I've got what I am told are "normal" rust spots inside the engine compartment right where the inner fender meets the firewall.
Thu Jul 28, 2011 10:24 am |
Got the driver side floor pan cut out. Got the new one fitted. Will weld it in tomorrow and work on a few other patches. Gonna order up some flairs and start cutting fenders.
Fri Jul 29, 2011 7:54 pm |
airbur
I finished reviving the last big panel....the tailgate today. Only things left are the window and windshield frames:)
Fri Jul 29, 2011 9:01 pm |
Started tearing my dash out to troubleshoot my no-start issue/possible prep for a new wiring harness. I hate Ford at the moment. Those stupid 7 screws in the dash panel from under the windshield frame added about 30 more minutes on to the job than I wanted.
Sun Jul 31, 2011 12:26 am |
Finally finished painting the bumper and got it mounted up. Now to find a spare!
Sun Jul 31, 2011 12:32 am |
finally eliminated the alternator belt squeal
I suppose the belt will stretch some more over the next few weeks and it will return
Sun Jul 31, 2011 3:45 am |
airbur
Finished polishing yesterday. Looks like a different truck:). Going to uninstall the tach today and see if Advance will warranty it.
Sun Jul 31, 2011 6:29 am |
Got the drivers side floor pan all cut out and the new one screwed in. Ready to be welded. Was just too damn hot outside to be welding. I really need a bigger garage. Was gonna order up my flairs so I cn start cutting fenders before I start prep for paint.
Sun Jul 31, 2011 6:32 am |
Sun Jul 31, 2011 7:11 am |
airbur
I think it's the other way around since I spent so much time on it! She's asking what she gets to do for an entire weekend now:)
Sun Jul 31, 2011 1:10 pm |
