It is currently Sat Nov 23, 2024 7:42 pm
Reply to topic  [ 2657 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18, 19, 20 ... 89  Next
power washed main/aux tanks, Main is ready to be boiled out, Cleaned both skid plates and applied some fresh black paint to them. Cleaned trans skid plate and painted. Purchased rear 9" Pinion seal, Exhaust manifold gaskets, and carb rebuild kit.
"Friendship is like peeing on yourself: everyone can see it, but only you get the warm feeling that it brings."
!974 Bronco, 4x4, 302/ auto trans, All original for now
Sun Jul 31, 2011 4:35 pm
Showed it off to RoxCrusher then spent some time and cleaned the dash.....looks about as good as the exterior now:)
Sun Jul 31, 2011 4:52 pm
Technically, Not today,, but today she fired for the first time in over a month!
Went from this due to my own lack of knowledge
Through vacation and recovering from a severely strained back to this
Finished buttoning it up Sunday night and wentt out today to recheck everything and fire it up, Ran it at 2k for 30 mins.
Still some things to look at, I have a vac leak at the base of the carb which is messing with getting the timing just right. I'll replace that tomorrow after things cool down and set the final adjustments.
First time ever doing anything like this and thanks for all the discussions to get me to this point. Dan, you were a huge resource for me and helped me from making some other mistakes.
Need to get the fenders and grill back on it and take it for a spin later this week as time permits.
Brett
Mon Aug 01, 2011 5:14 pm
Images: 1
Put the wild horses 2.5 lift springs in the back of the truck. And holy f, those things flex amazing. Oh and it sits a lot better than before too . Image
Mon Aug 01, 2011 10:48 pm
Yeah, that looks good!!
Tue Aug 02, 2011 7:13 am
Tue Aug 02, 2011 8:14 am
Tue Aug 02, 2011 8:44 am
Images: 1
Dreeded Bronco lean banghead
Tue Aug 02, 2011 9:16 am
Doing the mad scramble to make it to Ouray. Over the last few days I've done a DIY gear banger, painted the new shifter & twin stick. I should have all that buttoned up tonight. I also have to finish installing the Lock Rite locker, suspension limit straps & new treads.
Also cleaning up my house so my house/dog sitters have a decent place to stay. Since last Saturday, I've (with the help of lots of friends) ripped down several 1882 walls & and a ceiling amounting to 4 pick up trucks full of plaster, lath, & lumber. We've also framed up a few new walls, installed a 15' reclaimed beam, and sheet rocked the ceiling. My place is dirty!
Chad
Tue Aug 02, 2011 12:52 pm
Got it ready for trip to Ouray
checked and topped off all fluid levels
replaced stale air in the tires (just checking if your actually reading this)
checked to make sure I have tools, spare parts, and fluids
packed that sucker to the gills with camping gear
might just sleep in it tonight
Tue Aug 02, 2011 7:44 pm
Took my son for ice cream in it.
Tue Aug 02, 2011 7:53 pm
Images: 1
Tue Aug 02, 2011 9:19 pm
Tomorrow, I'm repacking my muffler bearings for good measure. Might change the blinker fluid if I have time.
Chad
Tue Aug 02, 2011 10:29 pm
Wed Aug 03, 2011 6:07 am
Went to Advance to pickup some vacuum line. I blocked off the manifold vac lines and connected the carb directly to the vac advance on the dizzy. Seems to be running fine. Also picked up oil filter and a Restore so did an oil change this evening. Amazing how black that stuff gets after only a 1000 miles or so.
Sun Aug 07, 2011 6:19 pm
Took my nephews on a couple of rides in the Bronco - had such a great time with the sun shining, top down, and music up. Thanks Viper for the quick turn-around on the transmission to make it possible - priceless to spend some quality time with them.
Mon Aug 08, 2011 10:55 pm
Tue Aug 09, 2011 6:00 am
Did you happen to see any full serpentine setups?
Tue Aug 09, 2011 6:44 am
Course....the "North location":) I think I should open up a you-pull shop down south here! Thanks for the info, I'm in the market for one of those.
Tue Aug 09, 2011 6:52 am
Ok -- No second job tonight so I am FINALLY going to have at least a couple three hours to tear into the old 302 that Frank and I pulled out of my 75 DBE. Wife is wanting an engine -- any engine -- back in the vehicle now, so I better get moving!
Tue Aug 09, 2011 9:26 am
4BT?? It's "any engine"...
Tue Aug 09, 2011 9:40 am
Ok, 4BT? You have to translate as I am new to Fords in general and Bronco's specifically. HAH!
Tue Aug 09, 2011 9:44 am
4BT is actually a cummins product. 4 cyliner diesel:
http://www.youtube.com/watch?v=M_HqhiW38ik
http://www.youtube.com/watch?v=BJE-oDoya14
6Bt is what's in the diesel dodge trucks.
Tue Aug 09, 2011 9:50 am
Had a buddy who added a turbo to his inline six and that thing would fly!! Plus it sounded AWESOME!
Tue Aug 09, 2011 10:05 am
Quick question -- what is the best way to remove the old gasket materials from where the intake manifold used to sit? And can I use something like brake cleaner to do a finish cleaning?
Tue Aug 09, 2011 8:47 pm
Tue Aug 09, 2011 8:50 pm
Ditto on the razor blade, finish it up by wiping it down with acetone.
Tue Aug 09, 2011 9:18 pm
Acetone -- I've got some of that. Perfect. The original engine has an Edeldbrock Torker 289 -- does that sound right? Ok to use on my "donor" engine or worth finding something else cheap to throw on the top of it? Thoughts?
Tue Aug 09, 2011 9:36 pm
Use it and see how you like it. Carbs are easy to swap out.
Tue Aug 09, 2011 10:13 pm
I pillaged a Mercury Mestique that was donated to one of our local volunteer fire departments. It will be used as practice for extrication, jaws of life, etc. It had a surprisingly nice interior, blue to boot, so it matches my truck. I grabbed the front seats, visors (w/lighted mirrors- its a Merc you know), a cigarette lighter, a nice overhead light, and an inertia switch. I really hope the seats can be used, they are sweet, but it won't be easy. The driver seat is electric, and may be difficult to make sit low enough to fit my legs under the steering wheel. The passenger seat does not have a quick release folding back, because it was from a 4 door car. I think I read somewhere that a Bronco II seat base can be used to flip the seat up and out of the way, for entering the back. Any suggestions? I told a friend that I may swap him the electric driver's seat for his manual seat, and just exchange seat covers, if I can't make it work.
Chad
Tue Aug 09, 2011 10:30 pm
32,981,572 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
