www.ColoradoClassicBroncos.com - View topic - crank pulley for 302 HELP
It is currently Fri Nov 15, 2024 5:28 pm
Reply to topic  [ 18 posts ]
Post crank pulley for 302 HELP
I'm looking for one of the last pieces to get my rig on the road and haven't had any luck finding it so far its a dual crankshaft pulley so I can run my powersteering its gonna be for a 302 has 4 holes 5 counting the center hole..I measured around 2 and 1/4th from the center of one hole to the other the big center hole is 2 and 1/4th as well if ur a distance from me I can pay for shipping as well
Im your huckleberry
Sat Aug 13, 2011 8:03 am
Post Re: crank pulley for 302 HELP
I go back to work on Monday...I take the measurements with me and see what I can find.
Old EB 1966 I-6 170
New EB 1970 V-8 302
Next EB ? 5.0 EFI
Sat Aug 13, 2011 11:27 pm
Cool deal just thought id put an ad up just incase u didn't have any luck..ill be off the next 4 days let me know if u have any luck and I can make a trip up real quick thanks
Im your huckleberry
Sun Aug 14, 2011 9:46 am
Oh yeah...better to have a few people looking for it. Sounds good... It'll be nice to have a front bumper finally...I'll let you know what I find.
Old EB 1966 I-6 170
New EB 1970 V-8 302
Next EB ? 5.0 EFI
Sun Aug 14, 2011 2:04 pm
Cool well either way if u find one or not u can still have the bumper u can use it more then I can..
Im your huckleberry
Sun Aug 14, 2011 3:04 pm
Thanks....was wondering if you know the diameter of the pulley...6 inches or so I imagine but you could probably use a different size by using longer or shorter belts. But just wanted to check in case that needs to be a specific size.
Old EB 1966 I-6 170
New EB 1970 V-8 302
Next EB ? 5.0 EFI
Sun Aug 14, 2011 7:28 pm
The single pulley I pulled off was around 6 and 3/4ths
Im your huckleberry
Mon Aug 15, 2011 11:39 am
I found a pulley that has the right bolt pattern and hole in the middle, but it's for three belts instead of two. Do you want this one or should I keep looking for a pulley for two belts? Let me know.
Old EB 1966 I-6 170
New EB 1970 V-8 302
Next EB ? 5.0 EFI
Mon Aug 15, 2011 1:46 pm
Hmm I guess keep that one on the side and if u cant find one ill try to make it work
Im your huckleberry
Mon Aug 15, 2011 2:53 pm
I stayed late at work and scoured the yard for a while...I found two that are made for two belts. They both have the correct bolt pattern and measurement and center hole diameter. One has two v channels flush to each other that are 6 1/4 inches in diameter (but one has a slight bend...I think it could be fixed), and the other has two v channels slightly apart and the inner channel is 7 inches and the outer is 8 inches. If that doesnt make since, I can take my camera to work tomorrow and take a picture of each of them. Hope one of these work for you...
Old EB 1966 I-6 170
New EB 1970 V-8 302
Next EB ? 5.0 EFI
Mon Aug 15, 2011 5:46 pm
Sounds like the bent one will work or pretty damn close heck kinda sounds like they both might work with different size belts I would think..
Im your huckleberry
Mon Aug 15, 2011 8:49 pm
Both pulleys are still on the engines and if you wanted, you could just meet me at work and i could pull the one you think would work best... My cell is 719-244-2759 if you want to do that. Also... If it only suited in the evening I could pull both and bring them home and you could meet me at my house. Whatever works best for you...
Old EB 1966 I-6 170
New EB 1970 V-8 302
Next EB ? 5.0 EFI
Mon Aug 15, 2011 9:23 pm
I think I read somewhere that running a pulley with 2 different diameters can cause problems with the belts wearing out quickly. I think I was reading something about putting double pulleys on an alternator. Am I making this up or what? I feel I may be wrong, I wouldn't think a manufacturer would use a part that caused problems like that. Sorry for the hijack.
Chad
Tue Aug 16, 2011 12:16 pm
Im your huckleberry
Thu Aug 18, 2011 5:23 pm
That's awesome....so is it up and running now or do you still have a ways to go? I'll keep my eyes open for a 35 inch tire. You are just looking for something to get you home right?? I might be able to find one of those at work. I appreciate the bumper offer...and if not before I know I'll be in Rocky Ford in October so I could get it then if it doesn't work out before...i'd be interested in meeting you part way if you are headed to Pueblo even. Glad you found a pulley that works!
Old EB 1966 I-6 170
New EB 1970 V-8 302
Next EB ? 5.0 EFI
Thu Aug 18, 2011 8:24 pm
I just need to bolt it on and buy some new belts and it should fire up didn't get to that today it was freaken hot out so I just installed my door inserts..wont be long ill have it on the road next week..and yeah ill let u know when I'm up ur way to drop that off..
Im your huckleberry
Thu Aug 18, 2011 8:36 pm
From the tiny avatar pic it looks great...did you paint your inserts to match already? Also...do you have a roll bar in it? Hope to see it sometime...it's a ways but closer than Denver...Saturday breakfast in the Springs...maiden voyage???
Old EB 1966 I-6 170
New EB 1970 V-8 302
Next EB ? 5.0 EFI
Thu Aug 18, 2011 9:51 pm
Yeah the inserts are allready painted and the roll cage is installed..I do have some pics under members rigs but haven't got any new ones up yet..wont be able to make the breakfast seems I wont get my rearend back till monday so I'm screwed there..I would have liked to though..next one for sure
Im your huckleberry
Fri Aug 19, 2011 2:48 pm
32,885,049 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
