Postby Gunnibronco » Thu Aug 11, 2011 4:24 pm
The mods of the driver seat are going very well. The driver seat did sit way to high on the stock mounting brackets. First, I pulled the cover & all the padding off. When the padding was off I realized I could retain the power seat back motor & the inflatable lumbar support! Sweeeeeeet! I'll loose the front & rear height motors & the motor that slides the seat forward & back, no biggie.
I cut off the lower mounting brackets & motor rack with a plasma cutter, and mounted my bronco sliders to the seat bottom. I just had to use some different pieces of square stock to make spacers to mount the sliders flat. Already bolted them in for a test fitting & it turned out perfect, just about where the stock seat height is. Tomorrow I'm going to clean up the sliders & oil them, recover & mount the seat, then I'll tap into power from the radio in the center console for the motors.
Chad
Postby airbur » Thu Aug 11, 2011 4:28 pm
Gunnibronco wrote:The mods of the driver seat are going very well. The driver seat did sit way to high on the stock mounting brackets. First, I pulled the cover & all the padding off. When the padding was off I realized I could retain the power seat back motor & the inflatable lumbar support! Sweeeeeeet! I'll loose the front & rear height motors & the motor that slides the seat forward & back, no biggie.
Chad
All that and no pics?!?!
airbur
Postby Gunnibronco » Thu Aug 11, 2011 4:29 pm
Sorry, doing it between jobs at work, didn't bring the camera. I'll try to remember to bring it tomorrow.
Chad
Postby socofn » Thu Aug 11, 2011 8:24 pm
Got the soft top installed yesterday. It looks real GOOD. Planning a short trip into the mountains next week to see what else I need to fix. I also ordered front shoulder seat belts. Jayson
74, MONEY EATER
socofn
Postby airbur » Thu Aug 11, 2011 8:30 pm
socofn wrote:Got the soft top installed yesterday. It looks real GOOD. Planning a short trip into the mountains next week to see what else I need to fix. I also ordered front shoulder seat belts. Jayson
Nice! I love our Bestop.
I got about 1/2 done stripping the paint and primer off the upper intake. Thanks to Dan for the Aircraft Stripper suggestion.
Also scored a 1989 EEC-IV A9L on eBay for $60!
airbur
Postby Gunnibronco » Fri Aug 12, 2011 5:36 pm
Alright, here are a couple pics of the 96 Merc Mestique seat. I got the driver seat bolted in today. I need to add power to get the motors working. There is trim panel that has the seat control buttons & a change pocket. It needs some trimming to fit. The old Bronco sliders work great. I can even push it back further than I would normally sit. With the seat pushed all the way back, I cannot push the clutch in completely.
First are a couple of the bottom of the seat after plasma cutting off the original motor assembly & mounting brackets.
Driver seat installed:
Postby airbur » Fri Aug 12, 2011 5:39 pm
Very nice!! Good work!:)
airbur
Postby Gunnibronco » Fri Aug 12, 2011 6:05 pm
Thanks,
I forgot a couple things, the Mestique is the same car as the Ford Contour. I know of 3 Ford Contours and none have electric seats. Just in case you run into one, the seats make a great donor. The seat width was actually about 1" narrower than the Bronco's. And the stock sliders bolted right through the remainder of the braces I cut off, in the back, the front of the sliders bolted through the front of the seat pan. You can see my pink marker on one brace, right near the holes I used to mount the sliders.
It is so comfortable, compared to my almost 40 year old driver's seat. It was way over due. The best part, the seats were FREE.
Postby Jesus_man » Fri Aug 12, 2011 7:24 pm
Find another set and I'll let you do the same for me...:) No power anything needed. Nice work!
Postby Gunnibronco » Fri Aug 12, 2011 7:39 pm
The driver side turned out easy. We'll see about the passenger side. I'm not holding my breath.
Chad
Postby Entourage » Fri Aug 12, 2011 9:04 pm
Which Soft Top did you go with? Let's see some pics.
Postby Entourage » Fri Aug 12, 2011 9:08 pm
I changed the oil for the first time. It was gross and definitely needed to be changed. Went with Mobil-1 Synthetic 10-30 and Mobil-1 Filter that was at least an inch longer than the one I took off. Thanks to ZOSO for helping find where to put the new oil. Expect him to change his phone number soon lmao
Postby Booger » Sat Aug 13, 2011 6:09 am
Entourage wrote:I changed the oil for the first time. It was gross and definitely needed to be changed. Went with Mobil-1 Synthetic 10-30 and Mobil-1 Filter that was at least an inch longer than the one I took off. Thanks to ZOSO for helping find where to put the new oil. Expect him to change his phone number soon lmao
Put it in the 710 hole. laughing2
Postby 75DBE » Sat Aug 13, 2011 9:12 am
Have the oil pan and valve covers off, removed old gasket material, prepping for paint and reassembly! Woo hoo.
75DBE
Postby 66and70Broncos » Sat Aug 13, 2011 5:02 pm
Welded broken window frame...welded piece of steel to rear tire carrier latch so it doesn't move so much...removed and painted. Dangit...didn't realize the screws went into a bracket inside the tailgate that is not attached. So after dinner I will be fishing with a magnet to get the bracket back to where I can attach the tailgate latch...how the heck are you supposed to get that in there and positioned? The only thing I can figure is to lay the tailgate down flat and fishbit around with a magnet. I don't plan on ever unscrewing it once I get it back together!
Old EB 1966 I-6 170
New EB 1970 V-8 302
Next EB ? 5.0 EFI
66and70Broncos
Postby Kinder » Sat Aug 13, 2011 5:49 pm
Remove the tailgate handle and you can push it into position, just watch the rods that connect to the latch, they can be a pain.
Postby 66and70Broncos » Sat Aug 13, 2011 7:24 pm
Yeah...I ended up putting tailgate down and laying on my back...took the latch handle off and used a magnet to get it close...and then a screw driver. It wasn't as bad as I thought it would be. Also rewelded my rocker that welds had broken on close to the door post...really helped make everything more solid and door closes better.
Old EB 1966 I-6 170
New EB 1970 V-8 302
Next EB ? 5.0 EFI
66and70Broncos
Postby mwlynch3 » Tue Aug 16, 2011 4:40 pm
Let's see....
Roll-on bedliner on the interior.
Painted the tire rack, bumpers, roll bar, and grill a nice white.
Fixed the stalling situation again.
Installed a stereo AND 6x9 speakers (in boxes).
Installed Bronco emblems on fenders (Thanks to my wife, anniversary gift).
Installed arm rests.
Slowly but surely.
MWL
mwlynch3
Postby Entourage » Tue Aug 16, 2011 7:52 pm
mwlynch3 wrote:Let's see....
Slowly but surely.
MWL
Mike - Way to cross a lot of things off the to-do list.
I took my family in the Bronco to Golden Spoon for some frozen yogurt - mmmmm.
Postby Rox Crusher » Tue Aug 16, 2011 7:55 pm
this week end I removed the tint from the door glass............gonna do the hardtop glass soon
just took my kiddos to the sonic for M&M blasts
Postby Dukietown » Tue Aug 16, 2011 8:04 pm
Worked on the doors, got hardware back into the lower hinge plate so both doors close properly now and don't feel like they're going to fall off when I open them. Tore apart my column to see if I could help Zilla out with the part he needed and to get my turn signal switch replaced.
Dukietown
Postby Jesus_man » Wed Aug 17, 2011 7:35 pm
Steering U-joint - I really, really need to replace that rag joint on mine.
Postby airbur » Wed Aug 17, 2011 8:02 pm
I patched up the soft top with a vinyl adhesive kit. Actually turned out pretty good. I glued up both sides and didn't even use the supplied color and texture match items.
airbur
Postby socofn » Wed Aug 17, 2011 8:08 pm
Drove it to work and had the light switch fall out. I had a he** of a time getting the lights to turn off. I then filled it up with gas and the *************** gas gauge quit working, again. I ordered a new light switch and will get in this weekend. I do like this thing but it has driving me everywhere but where I need to go. Jayson
74, MONEY EATER
socofn
Postby Entourage » Fri Aug 19, 2011 4:16 pm
Drove mine to work today for the first time and smiled the whole way. On my way home from work, I picked up my daughter from school.
Postby cobshane » Fri Aug 19, 2011 5:12 pm
zillacon wrote:My steering column showed up so I installed that and took Ketchup for a spin. Made some nice posi marks up my driveway. LOL burnout
Saaweet, lets see some of those pics of the EFI setup in dat machine.
cobshane
Images: 1
Postby kchaser » Fri Aug 19, 2011 6:34 pm
Picked up my HP king pin Dana60 front and matching rear. Now the real work begins...
kchaser
Postby Jesus_man » Fri Aug 19, 2011 7:00 pm
kchaser wrote:Picked up my HP king pin Dana60 front and matching rear. Now the real work begins...
You're getting serious!!
Postby cobshane » Fri Aug 19, 2011 10:04 pm
very nice setup!
cobshane
Images: 1
Postby Justin » Sat Aug 20, 2011 12:17 am
Got a bunch of little things done in the last week. Opened up both doors and replaced the window regulator bushings. Replaced the rear track in the driver's side door. Fixed the incompetent (by current owner, this time) wiring on the cigarette lighter. Took out the old radiator, got the mounts installed for the new one. Gave it a bath, starting with a hosing of the interior. As much as I'd like a quieter truck, I really am glad I don't have carpet.
Return to Chit Chat
