www.ColoradoClassicBroncos.com - View topic - new here and have qustion
It is currently Thu Oct 31, 2024 7:24 pm
Reply to topic  [ 21 posts ]
Post new here and have qustion
So bought my first bronco today 72 w a 302 three speed on the floor. Really excited runs but I think the transfer case is shot . Got it at a great price . Where should I go from here should I rebuild it or just replace it ?
Sat Nov 13, 2010 12:10 am
Post Re: new here and have qustion
Sat Nov 13, 2010 12:19 am
No its red and has a top. It turns fine, it will only go 4l and N. J shift, bought it this way and have not attempted anything yet, drive shafts are off . the guy i bought it from really did a number and took a bunch of stuff apart. so I dont know the actual symptons yet I just know what he said and that was that the transfer case was shot. motor is strong everything so far seems good he just took it apart before i had a chance to really look at it.
Sat Nov 13, 2010 12:16 pm
J shift transfer cases are notorious for poor shifting, I wouldn't rule out a worn shifter versus the transfer case. But the 72 should have come stock w/a T shift case so something has changed since it was new. Once you get into it further pull the boot off and take a look at how the shifter attaches to the case, see if something is loose, then take the next step as needed.
Sun Nov 14, 2010 1:13 am
A very common problem when the tcase/trans is taken out and rebuilt by a novice. The tcase input gear can be put on backwards and it will cause those exact symptoms. Take the bottom cover off the tcase and snap a pic of the input gear (first gear after the trans) with the tcase in neutral and I can tell you if that's what it is. Easy to fix.
Sun Nov 14, 2010 8:05 pm
opps ok it is a t shift, pulled it out today and putting a new one in tomorrow, easy enough to get out.
Sun Nov 14, 2010 8:45 pm
Nice job - looks like you will back on the road in no time. Do we get to see pics of the Bronco?
Sun Nov 14, 2010 8:48 pm
Sun Nov 14, 2010 10:21 pm
well put in a new transfer case, now it looks like the rear shaft snapped right at the yoke, and I put in a twin stick, I appear to have to clutch.... I can not get it into gear at all, any suggestions on either problem????? Thanks.
Sat Nov 20, 2010 12:52 am
The complete rear ouput assembly from the old tcase will exchange with the new one. You only need to remove the rear driveshaft to swap it. If you're careful you won't even drop the 13 roller bearings at the front of the output shaft. If the shaft is broke I wouldn't be surprized if it doesn't go into gear.
Sat Nov 20, 2010 1:08 am
here are some pics of the rear, and the bronco, do I need to replace the whole shaft?
Sat Nov 20, 2010 1:12 am
Oh, I thought you were talking about the rear output shaft. Driveshaft is an easy fix.
Sat Nov 20, 2010 9:31 am
Ya tried it with no drive shaft hooked up still won't go into gear
Sat Nov 20, 2010 10:48 am
Did you check the input gear like I posted above?
Sat Nov 20, 2010 12:40 pm
when i pulled the transfer case it stayed in place, I packed the pins on the inside on the transfer case and put it back, if it moved around when installing would that throw off my clutch?
Sat Nov 20, 2010 1:01 pm
Sat Nov 20, 2010 1:13 pm
great thanks, ill give it a shot.
Sat Nov 20, 2010 1:17 pm
Ok ..... I got the TC in the right way..... i did the damage to the drive shaft, no clutch and I guess I had it in gear with my foot on the brake.... could I get some help with the shift pattern for 3 on the floor ???? Thanks. I know that sounds stupid but I cant figure it out. Now on to the next one, I am pulling the tranny tomorrow, and taking the shaft in the repairs, Is it common for these to have clutch problems or could it just be the linkage? and what oil should be in this Tranny.....
Sun Nov 21, 2010 8:08 pm
R 2
1 3
Reverse is left then forward
First is left then back
Second is Right then forward
Third is right then back
Sun Nov 21, 2010 9:56 pm
Usually 90 wt gear oil for a regular 3 spd, there is also some variable wt oil out that ranges 75-90 wt that will probably make it easier shifting in the cold.
Mon Nov 22, 2010 1:15 pm
I might have a line on a cheap 3spd and t-case if you're interested. Should be a T-shift (which have a 2-low if you can find it). My father-in-law pulled his out of his bronco in favor of a NP435 and a NP205.
Mon Jan 10, 2011 11:50 am
32,732,990 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
