new here and have qustion
Postby jlelms » Fri Nov 12, 2010 11:10 pm
So bought my first bronco today 72 w a 302 three speed on the floor. Really excited runs but I think the transfer case is shot . Got it at a great price . Where should I go from here should I rebuild it or just replace it ?
jlelms
Re: new here and have qustion
Postby akaFrankCastle » Fri Nov 12, 2010 11:19 pm
jlelms wrote:So bought my first bronco today 72 w a 302 three speed on the floor. Really excited runs but I think the transfer case is shot . Got it at a great price . Where should I go from here should I rebuild it or just replace it ?
This 72 wouldn't happen to be black/dark in color and lacking a top would it?
What symptoms are you experiencing with the transfer? Stuck in one gear and won't come out? Grinding noises? Break it down for us.
Postby jlelms » Sat Nov 13, 2010 11:16 am
No its red and has a top. It turns fine, it will only go 4l and N. J shift, bought it this way and have not attempted anything yet, drive shafts are off . the guy i bought it from really did a number and took a bunch of stuff apart. so I dont know the actual symptons yet I just know what he said and that was that the transfer case was shot. motor is strong everything so far seems good he just took it apart before i had a chance to really look at it.
jlelms
Postby Kinder » Sun Nov 14, 2010 12:13 am
J shift transfer cases are notorious for poor shifting, I wouldn't rule out a worn shifter versus the transfer case. But the 72 should have come stock w/a T shift case so something has changed since it was new. Once you get into it further pull the boot off and take a look at how the shifter attaches to the case, see if something is loose, then take the next step as needed.
Postby Viperwolf1 » Sun Nov 14, 2010 7:05 pm
A very common problem when the tcase/trans is taken out and rebuilt by a novice. The tcase input gear can be put on backwards and it will cause those exact symptoms. Take the bottom cover off the tcase and snap a pic of the input gear (first gear after the trans) with the tcase in neutral and I can tell you if that's what it is. Easy to fix.
Postby jlelms » Sun Nov 14, 2010 7:45 pm
opps ok it is a t shift, pulled it out today and putting a new one in tomorrow, easy enough to get out.
jlelms
Postby Entourage » Sun Nov 14, 2010 7:48 pm
Nice job - looks like you will back on the road in no time. Do we get to see pics of the Bronco?
Postby Viperwolf1 » Sun Nov 14, 2010 9:21 pm
jlelms wrote:opps ok it is a t shift, pulled it out today and putting a new one in tomorrow, easy enough to get out.
The input gear stays in the adapter when the tcase is pulled. In this pic the left side of the gear goes towards the adapter and the right side goes towards the tcase.Image
Postby jlelms » Fri Nov 19, 2010 11:52 pm
well put in a new transfer case, now it looks like the rear shaft snapped right at the yoke, and I put in a twin stick, I appear to have to clutch.... I can not get it into gear at all, any suggestions on either problem????? Thanks.
jlelms
Postby Viperwolf1 » Sat Nov 20, 2010 12:08 am
The complete rear ouput assembly from the old tcase will exchange with the new one. You only need to remove the rear driveshaft to swap it. If you're careful you won't even drop the 13 roller bearings at the front of the output shaft. If the shaft is broke I wouldn't be surprized if it doesn't go into gear.
Postby jlelms » Sat Nov 20, 2010 12:12 am
here are some pics of the rear, and the bronco, do I need to replace the whole shaft?
jlelms
Postby Viperwolf1 » Sat Nov 20, 2010 8:31 am
Oh, I thought you were talking about the rear output shaft. Driveshaft is an easy fix.
Postby jlelms » Sat Nov 20, 2010 9:48 am
Ya tried it with no drive shaft hooked up still won't go into gear
jlelms
Postby Viperwolf1 » Sat Nov 20, 2010 11:40 am
Did you check the input gear like I posted above?
Postby jlelms » Sat Nov 20, 2010 12:01 pm
when i pulled the transfer case it stayed in place, I packed the pins on the inside on the transfer case and put it back, if it moved around when installing would that throw off my clutch?
jlelms
Postby Viperwolf1 » Sat Nov 20, 2010 12:13 pm
jlelms wrote:when i pulled the transfer case it stayed in place, I packed the pins on the inside on the transfer case and put it back, if it moved around when installing would that throw off my clutch?
But if the gear was put in wrong previously it's still wrong. I'd pull the bottom cover plate from the tcase and verify the input is on the correct way. If it's in wrong you won't see the dogs on the end of the gear.
Postby jlelms » Sat Nov 20, 2010 12:17 pm
great thanks, ill give it a shot.
jlelms
Postby jlelms » Sun Nov 21, 2010 7:08 pm
Ok ..... I got the TC in the right way..... i did the damage to the drive shaft, no clutch and I guess I had it in gear with my foot on the brake.... could I get some help with the shift pattern for 3 on the floor ???? Thanks. I know that sounds stupid but I cant figure it out. Now on to the next one, I am pulling the tranny tomorrow, and taking the shaft in the repairs, Is it common for these to have clutch problems or could it just be the linkage? and what oil should be in this Tranny.....
jlelms
Postby ClayJ » Sun Nov 21, 2010 8:56 pm
R 2
1 3
Reverse is left then forward
First is left then back
Second is Right then forward
Third is right then back
ClayJ
Postby Kinder » Mon Nov 22, 2010 12:15 pm
Usually 90 wt gear oil for a regular 3 spd, there is also some variable wt oil out that ranges 75-90 wt that will probably make it easier shifting in the cold.
Postby Jesus_man » Mon Jan 10, 2011 10:50 am
I might have a line on a cheap 3spd and t-case if you're interested. Should be a T-shift (which have a 2-low if you can find it). My father-in-law pulled his out of his bronco in favor of a NP435 and a NP205.
