www.ColoradoClassicBroncos.com - View topic - resplining shafts
It is currently Sat Nov 02, 2024 6:23 am
Reply to topic  [ 13 posts ]
 resplining shafts
Post resplining shafts
Anyone know a good local place that can do some custom shaft splining?
Sat Nov 20, 2010 10:21 am
Post Re: resplining shafts
I have never used them but have heard good things from people that have. Masterline Axle. They are down off of Hampden and Santa-fe. 1-800-525-1963.
What are you trying to get some splines into?
Sat Nov 20, 2010 10:31 am
I'm toying with the idea of resplining a transmission shaft. If rear axles shafts can be resplined I don't see why I can't do the same for a trans shaft. There appears to be plenty of material for what I want to do and the trans shaft only see's about 1/10th the torque of a rear axle. I just need to see if it's going to be cost effective.
Sat Nov 20, 2010 11:13 am
i believe moser does it too, but you would have to mail them the part
Sat Nov 20, 2010 10:23 pm
Call Scott at Rockstomper, he should be able to do it locally and his work is top notch.
'69 narrowed 8". Parts of the frame rails are original.
Sun Nov 21, 2010 10:07 am
Viper, how did this work out?
I just found in my box o' goodies, a c4 to d20 adapter, output shaft and bearing retainer, if you need??
Thu Nov 25, 2010 12:23 am
Thu Nov 25, 2010 10:56 am
I live in the springs but all my axle machine work including respline and BC WAH install was done by High Plains Tool and Mold in Sheridan.
Wed Dec 08, 2010 11:18 pm
That's a helluva drive for a machine shop. Those boys must do some excellent work.
Wed Dec 08, 2010 11:30 pm
...how did the resplining go?
I have to ask, what are you up to?
Wed Jan 05, 2011 11:03 pm
Still not done. Too many irons, not enough funding. I'm trying to make some cheap Bronco C4 output shafts.
Sat Jan 08, 2011 6:09 pm
Fri Jan 14, 2011 12:18 am
Bringing this back up. I went over to High Plains Tool to see if they could do this but they were closed. I talked to a neighbor and was told Tom Staub suffered a stroke in December and his shop is at least temporarily closed.
I called Masterline and was told they don't do resplining. Too bad because their website reads like they have all the equipment to do it.
So I'm still looking.
Tue Feb 15, 2011 4:33 pm
32,753,429 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
