Postby Justin » Mon Aug 29, 2011 10:30 pm
Channeled my inner Viper and drilled and tapped my rear axle housing for a drain. Scariest thing I've done in awhile. Came out great, but would have been a really bad thing to screw up.
Postby Dukietown » Tue Aug 30, 2011 6:46 am
Loads of little stuff. Removed the old auto shift collar and shift tube, replaced with a smooth collar. New turn signal switch and flasher fuses but still only have 1 working signal. Put the rest of the steering back together and pulled the signal cam off the old wheel the PO had left which was a nice bonus. Put the passenger side door back together and all the handles/locks work finally. Small stuff but getting closer to taking it out for at least 1 camping trip before the summer's over!
Dukietown
Postby Rox Crusher » Tue Aug 30, 2011 10:21 am
zillacon wrote:Took Ketchup over to Exhaust Pros to get a price to hack off my new dual exhaust and have them do two into one like Mustard to resolve my vapor lock issue. Taking it in tomorrow.
So the exhaust is too close to the fuel lines (I thought you ran them on the outside of the frame).
I like your dual exhaust set up. Hopefully they can re-use some of it.
Postby Kinder » Tue Aug 30, 2011 11:38 am
How about running the fuel line on top of the frame, seems popular, though it would be a problem to get at.
Postby socofn » Tue Aug 30, 2011 7:44 pm
Got in the bronco and went to fire it up and the starter went crack and then spun. I was able to get it out this am and lots of little pieces fell out. I replaced it and it started right up. I also bought a new water pump and thermostat to get on the next couple of days. Jayson
74, MONEY EATER
socofn
Postby Kinder » Thu Sep 01, 2011 1:54 pm
Opened storage unit - check, all fluids full - check, re-connect battery - check, crank her a few times w/ out gas to get the oil flowing - check, three pumps and that sweet sound of headers - check, washed funk off from when I put it away dirty - check, filled the tanks and she is ready to roll - CHECK!
Postby Moab Mike » Thu Sep 01, 2011 4:17 pm
kinder wrote:Opened storage unit - check, all fluids full - check, re-connect battery - check, crank her a few times w/ out gas to get the oil flowing - check, three pumps and that sweet sound of headers - check, washed funk off from when I put it away dirty - check, filled the tanks and she is ready to roll - CHECK!
Welcome Home! burnout
Moab Mike
Postby Rox Crusher » Thu Sep 01, 2011 7:27 pm
Installed new wheel for wheelin'
Postby ZOSO » Fri Sep 02, 2011 5:06 am
hopefully start it today. Get my flat tire fixed. maybe go for a drive around the block. Havent drove it since the memorial day fun run.
Postby airbur » Fri Sep 02, 2011 5:12 am
Rox Crusher wrote:Installed new wheel for wheelin'
Wow! I think that is officially "Bronco Bling" foshizzle
airbur
Postby sbolt19 » Fri Sep 02, 2011 10:09 am
That looks like a Mustang steering wheel....Is it?
sbolt19
Postby socofn » Fri Sep 02, 2011 10:16 am
Got the new water pump in and new hoses placed. I took the radiator to a place to have it boiled and cleaned. Should be able to pick it up today and hopefully get it reinstalled in the am.
Hope everyone has a good weekend out doors. I have to work nights all weekend and will be lucky to even drive the bronco. Jayson
74, MONEY EATER
socofn
Postby ZOSO » Fri Sep 02, 2011 4:01 pm
ZOSO wrote:hopefully start it today. Get my flat tire fixed. maybe go for a drive around the block. Havent drove it since the memorial day fun run.
I started it today. First time in about a month. turned the key on and let the pump fill the carb. 2 pumps on the go peddle and hit the key. Fired right up. Gotta love that. burnout
Postby hockeydad4-22 » Fri Sep 02, 2011 9:15 pm
Started to install the new harness... Have I mentioned how much I dislike wiring?
But it will be nice when it isfinished, that's for sure
Postby ZOSO » Sat Sep 03, 2011 4:02 pm
on the 79 Got the flat fixed. Hooked up the OBA and tested. Took it for a short drive to make sure its gonna run. Just gotta get some gas in the morning.
Postby airbur » Sat Sep 03, 2011 4:40 pm
hockeydad4-22 wrote:Started to install the new harness... Have I mentioned how much I dislike wiring?
I do not envy that job! Why don't you pull the dash? Would make it easier, no?
airbur
Postby socofn » Sat Sep 03, 2011 9:59 pm
Got 4 new tires from discount at a pretty good price as my son is working there along with a $100 rebate. I should have them mounted up later this week and will take some pictures. Jayson
74, MONEY EATER
socofn
Postby Entourage » Sat Sep 03, 2011 10:38 pm
socofn wrote:Got 4 new tires from discount at a pretty good price as my son is working there along with a $100 rebate. I should have them mounted up later this week and will take some pictures. Jayson
Which tires did you go with?
Postby socofn » Sat Sep 03, 2011 11:10 pm
Hankook ATM, 33x12.5 15. Jayson
74, MONEY EATER
socofn
Postby hockeydad4-22 » Sun Sep 04, 2011 6:30 am
We did- just don't have a steering wheel puller at home so we can't get it all the way out. It is sitting there lose. Still have about 50% of the connections to make under the dash and the tail lights. hopefully by lunch we can be cruising.
Postby Shawns Fords » Sun Sep 04, 2011 3:09 pm
I will be at the shop tomorrow, I can bring my puller over if you need it. I can give you a hand with some of that, maybe some pointers because I know you like to do that yourself. laughing2
Shawns Fords
Postby airbur » Sun Sep 04, 2011 6:40 pm
Met up with Colorado75Bronco (Cory) and his wife and handed off my 351w heads and a whole box of goodies. Got to check out his sweet extended radius arms....that boy can lay a mean weld bead!
airbur
Postby 71 bass boat » Mon Sep 05, 2011 11:26 pm
A friend and i cut out all of the rust on the passenger side floor board ,kick panel and seat mount and replaced with all new metal. And fixed the nut in side the windshield frame on the driver side. got's new floors now! all i got left for metal work is the tranny tunnel but i'll do that after i install my 1 inch body lift. Welding
71 bass boat
Postby hockeydad4-22 » Tue Sep 06, 2011 5:20 am
Thanks to the Bronco Hut for being open on a holiday and for having a complete correct used harness, and thanks to all the help from Shawn of 69 bronco fame, we are nearly complete in the new harness install.
Just hoping that a new and correct module will finish the heavy lifting tonight. Then tidy up some lose end, install some wire looms and reinstall the dash, then free bird fly once again
Folks, I would like to take a moment to place a shout out to the bronco hut: Yesterday was my first time dealing with them. It will not be my last. They are great people who are working hard to build a business in a difficult economy. The good news is that they are about to become somewhat more convient. They are opening a shop in castle rock complete with paint booth that we can rent to paint our own vehicles. They are also branching out into other classic cars. Mustangs, camaros, etc. they will be able to help you. Those of you who are in the process of beautifying your rigs should give them a call. Fenders are on sale right now and Melissa informed me that she always keeps new tailgates and grills in stock at below standard dealer cost.
Postby airbur » Tue Sep 06, 2011 5:28 am
hockeydad4-22 wrote:Folks, I would like to take a moment to place a shout out to the bronco hut: Yesterday was my first time dealing with them. It will not be my last. They are great people who are working hard to build a business in a difficult economy. The good news is that they are about to become somewhat more convient. They are opening a shop in castle rock complete with paint booth that we can rent to paint our own vehicles. They are also branching out into other classic cars. Mustangs, camaros, etc. they will be able to help you. Those of you who are in the process of beautifying your rigs should give them a call. Fenders are on sale right now and Melissa informed me that she always keeps new tailgates and grills in stock at below standard dealer cost.
X2!! They are great down-home Bronco folk and I always ask Melissa and Dana about parts I'm looking for before going with the out-of-state shops. Sometimes the others are cheaper and carry items the Hut doesn't...but that happens rarely.
I can't wait for their new Bronco/Mustang shop in downtown Castle Rock to open up! They are going to throw a big party and I think we should thank them with a big turnout.
airbur
Postby hockeydad4-22 » Tue Sep 06, 2011 6:55 am
I can't wait for their new Bronco/Mustang shop in downtown Castle Rock to open up! They are going to throw a big party and I think we should thank them with a big turnout.[/quote]
I agree. I think about 40 bronco's parked in front of their building along with any other classic cars would look amazing, and who knows, it might even be a picture that ends up on the front page of their web site. Then your rig would be famous.
Postby socofn » Tue Sep 06, 2011 10:51 am
Got the re-worked radiator in this am, the folks a the radiator shop had to replace a couple of the tubes and acid dipped it and then boiled it out, they also painted it and it does look better. I ran it for 45min and then checked the temp with a laser at diff locations and found that it is running 30-45 deg cooler. Happy to have this done. Jayson
74, MONEY EATER
socofn
Postby socofn » Tue Sep 06, 2011 8:15 pm
here is a picture of it sitting in the garage with the new top minus the windows. I am going to get rid of the 35's on craigslist in the next couple of weeks after I post them up here if anyone is interested let me know. Jayson
74, MONEY EATER
socofn
Postby Justin » Tue Sep 06, 2011 10:45 pm
If you have a 5th one I might be interested in it as a spare.
Postby socofn » Tue Sep 06, 2011 11:17 pm
I do have 5, will let you know as i want to sell them all together if possible. Jayson
74, MONEY EATER
socofn
Return to Chit Chat
