Channeled my inner Viper and drilled and tapped my rear axle housing for a drain. Scariest thing I've done in awhile. Came out great, but would have been a really bad thing to screw up.
Mon Aug 29, 2011 11:30 pm |
Dukietown
Loads of little stuff. Removed the old auto shift collar and shift tube, replaced with a smooth collar. New turn signal switch and flasher fuses but still only have 1 working signal. Put the rest of the steering back together and pulled the signal cam off the old wheel the PO had left which was a nice bonus. Put the passenger side door back together and all the handles/locks work finally. Small stuff but getting closer to taking it out for at least 1 camping trip before the summer's over!
Tue Aug 30, 2011 7:46 am |
Tue Aug 30, 2011 11:21 am |
How about running the fuel line on top of the frame, seems popular, though it would be a problem to get at.
Tue Aug 30, 2011 12:38 pm |
socofn
Got in the bronco and went to fire it up and the starter went crack and then spun. I was able to get it out this am and lots of little pieces fell out. I replaced it and it started right up. I also bought a new water pump and thermostat to get on the next couple of days. Jayson
Tue Aug 30, 2011 8:44 pm |
Opened storage unit - check, all fluids full - check, re-connect battery - check, crank her a few times w/ out gas to get the oil flowing - check, three pumps and that sweet sound of headers - check, washed funk off from when I put it away dirty - check, filled the tanks and she is ready to roll - CHECK!
Thu Sep 01, 2011 2:54 pm |
Moab Mike
Thu Sep 01, 2011 5:17 pm |
Installed new wheel for wheelin'
Thu Sep 01, 2011 8:27 pm |
hopefully start it today. Get my flat tire fixed. maybe go for a drive around the block. Havent drove it since the memorial day fun run.
Fri Sep 02, 2011 6:06 am |
airbur
Fri Sep 02, 2011 6:12 am |
sbolt19
Fri Sep 02, 2011 11:09 am |
socofn
Got the new water pump in and new hoses placed. I took the radiator to a place to have it boiled and cleaned. Should be able to pick it up today and hopefully get it reinstalled in the am.
Hope everyone has a good weekend out doors. I have to work nights all weekend and will be lucky to even drive the bronco. Jayson
Fri Sep 02, 2011 11:16 am |
Fri Sep 02, 2011 5:01 pm |
Started to install the new harness... Have I mentioned how much I dislike wiring?
But it will be nice when it isfinished, that's for sure
Fri Sep 02, 2011 10:15 pm |
on the 79 Got the flat fixed. Hooked up the OBA and tested. Took it for a short drive to make sure its gonna run. Just gotta get some gas in the morning.
Sat Sep 03, 2011 5:02 pm |
airbur
Sat Sep 03, 2011 5:40 pm |
socofn
Got 4 new tires from discount at a pretty good price as my son is working there along with a $100 rebate. I should have them mounted up later this week and will take some pictures. Jayson
Sat Sep 03, 2011 10:59 pm |
Sat Sep 03, 2011 11:38 pm |
socofn
Hankook ATM, 33x12.5 15. Jayson
Sun Sep 04, 2011 12:10 am |
Sun Sep 04, 2011 7:30 am |
Shawns Fords
Sun Sep 04, 2011 4:09 pm |
airbur
Met up with Colorado75Bronco (Cory) and his wife and handed off my 351w heads and a whole box of goodies. Got to check out his sweet extended radius arms....that boy can lay a mean weld bead!
Sun Sep 04, 2011 7:40 pm |
71 bass boat
Joined: Wed Dec 08, 2010 3:49 pm Posts: 128 Images: 0
A friend and i cut out all of the rust on the passenger side floor board ,kick panel and seat mount and replaced with all new metal. And fixed the nut in side the windshield frame on the driver side. got's new floors now! all i got left for metal work is the tranny tunnel but i'll do that after i install my 1 inch body lift.
_________________ 71 bronco 5.5 lift 35's dana 44, 9 inch locked in the rear 4 wheel disc brakes np435 and finaly power steering!!!
Tue Sep 06, 2011 12:26 am |
Thanks to the Bronco Hut for being open on a holiday and for having a complete correct used harness, and thanks to all the help from Shawn of 69 bronco fame, we are nearly complete in the new harness install.
Just hoping that a new and correct module will finish the heavy lifting tonight. Then tidy up some lose end, install some wire looms and reinstall the dash, then free bird fly once again
Folks, I would like to take a moment to place a shout out to the bronco hut: Yesterday was my first time dealing with them. It will not be my last. They are great people who are working hard to build a business in a difficult economy. The good news is that they are about to become somewhat more convient. They are opening a shop in castle rock complete with paint booth that we can rent to paint our own vehicles. They are also branching out into other classic cars. Mustangs, camaros, etc. they will be able to help you. Those of you who are in the process of beautifying your rigs should give them a call. Fenders are on sale right now and Melissa informed me that she always keeps new tailgates and grills in stock at below standard dealer cost.
Tue Sep 06, 2011 6:20 am |
airbur
Tue Sep 06, 2011 6:28 am |
I can't wait for their new Bronco/Mustang shop in downtown Castle Rock to open up! They are going to throw a big party and I think we should thank them with a big turnout.[/quote]
I agree. I think about 40 bronco's parked in front of their building along with any other classic cars would look amazing, and who knows, it might even be a picture that ends up on the front page of their web site. Then your rig would be famous.
Tue Sep 06, 2011 7:55 am |
socofn
Got the re-worked radiator in this am, the folks a the radiator shop had to replace a couple of the tubes and acid dipped it and then boiled it out, they also painted it and it does look better. I ran it for 45min and then checked the temp with a laser at diff locations and found that it is running 30-45 deg cooler. Happy to have this done. Jayson
Tue Sep 06, 2011 11:51 am |
socofn
here is a picture of it sitting in the garage with the new top minus the windows. I am going to get rid of the 35's on craigslist in the next couple of weeks after I post them up here if anyone is interested let me know. Jayson
Tue Sep 06, 2011 9:15 pm |
If you have a 5th one I might be interested in it as a spare.
Tue Sep 06, 2011 11:45 pm |
socofn
I do have 5, will let you know as i want to sell them all together if possible. Jayson
Wed Sep 07, 2011 12:17 am |
